Why does our central heating braemar come up asking to reset once it reaches temp
    Sergeant:
  • 296 Answers
What's the model numbet?
Posted on Mar 30, 2019
6ya staff
SOURCE:
francis rivero
  • 958 Answers
SOURCE: central air
may i asked what kind of thermostat you are using? is it a digital or a mechanical one.
it could be out of calibration..
try experimenting with it...
right now if your setting is 75 F and its cutting at 78F then try to lower the setting to 73 F and it might cut off at 75 F then you would know that you have a bad thermostat or a theremostat with a little bit off in calibration...
i hope i was able to solve ur problem
pls rate me...
tnx 4 using fixya..
drcool
Posted on Jul 23, 2008
Anonymous
SOURCE: ariston micro genus combi boiler
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Posted on Dec 09, 2008
Anonymous
  • 16 Answers
SOURCE: Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Posted on Aug 17, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: My oven won't heat. The control panel appears
You need to replace the "sensor" in the oven. Here is a link to the part you need.
Posted on Aug 20, 2011
cameron_goul
cameron_goul
  • 108 Answers
SOURCE: 99 audi a6 2.4 oil light and abs flashes, rev counter stops working and auto box malfunctions.
is it just the instruments that are acting up? if so thats probably a bad connection somewhere that, when in a certain temperature zone, say from 90 degrees to 130 for example, doesnt have enough current but when heated, regains the current. but if you mean "auto box malfunctions" as in your automatic transmission does not work, then its time to have some pros take a look at it.
Posted on Oct 27, 2012
Braemar heater control unit showing flashing reset
Your Braemar control unit is indicating that it needs to be reset to continue operating.
Jul 07, 2018 | Heating & Cooling
MY BRAEMAR th5X23E showing reset -05 heater is not working at all
Go to the outside unit and open the door that covers the electrical connections. There will be a reset button on one of the temp switches that needs to be pushed. Now you have to see why it needs a reset.
Mar 21, 2014 | Heating & Cooling
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Heat will not turn off.Removed thermostat wile
Hello
Could be a stuck control relay,Tsat completes a circut for this relay to engage,once relay contacts are closed heater will start.and stay on until you reach temp.
once temp is reached relay will open and heat will shut down.
By disconnecting all power to heater your forceing relay to open.or simulating a satisfied temp.
I would have a service tech look at your control relay and t stat.
Jan 28, 2010 | Goodman Heating & Cooling
My honeywell central heating system turns off on its own. I set the room temp., the heating system reaches that temp then just turns off. The temperature drops and the system does not kick back on again to...
Hi, Just to let you know I have repaired central Heat & Air systems for 33 years and Have seen this problem on many occasions. Lets see if I can save you so many trips.It says you have a programmable stat? On this stat and on a mechanical stat, they have what is called a heat anticipator that controls how many and how often your thermostat turns you're unit off and on and how long it cycles after the stat is satisfied. If you have ever seen under the cover of a mechanical stat, ( mercury switch type) you will see a dial with an arrow with numbers as .1, .3, .4 1.0, or .15 to 1.0 amps.Some are fixed and some are adjustable. On a digital stat, you will have to get into the program and see what the heat anticipator is set on. They come from the factory at .4, but to really find out what you'res should be it takes an amprobe to do this. The setting you need is what you're gas valve requires.I am sure I have lost you, but I am just giving you a little food for thought. If you can get into you're program and set this to .4, great. If the problem continues, your anticipator on this stat is more than likely, shorted, which would require you to buy a new stat.With a shorted anticipator, it will seem to be working like you say, but when satisfied, the temp.keeps falling until you reset power, then it fires and repeats this. Change the stat. If this is central heat and air, just follow red-rc which will have a red jumper to rh for heat, white to w, green to g=fan, and yellow or blue to y = cooling. If you have central heat only, you will find 2 wires red and white.Red to rh with jumper still installed to rc and then white to w.This is quite a long explanation, but I wanted you to know a little more then the next guy about your stat. Please let me know.
Sincerely,
Shastalaker7
Nov 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
