I will say that if you dont have some type of air conditioning or dehumidification you run the risk of returning to a house with mold. Set the thing to 82, have a maintenance performed by a qualified technician, and possibly hire a house watch or have family check the place periodically.
Good explanation Merlin
If I was you I would pull the power disconnect to the condensing unit. You may also want to cover the condenser only to keep dogs or cats from urinating on the unit. If there is no possable way that will happen no need to cover it. When you come back in7 monts make sure the breaker is off to unit and wash condensing coil with high pressure from garden hose.
SOURCE: BSNL BROADBAND DOWNLOAD LIMIT EXCEEDS
This can happens when Automatic Updates Feature is Turn On. Your antivirus definitions updations. By using peer to peer softwares like bitcomet, bittorrent, Bitlord etc., These can work in bacground and downloads the updates and softwares and shares the resources of the downloads. By these the limit can exceed.
To reduce these risk factors
Change 250 Plan to 500 limited plan or 750 Home unlimited.
If not disable the autoupdates feature.
Hope this will be usefull
Thanks & Regards.
Nanda Kishore
SOURCE: I installed a Fujitsu ductless split system lines freeze on one
do you have a kink in that suction line?
SOURCE: how to pump down a ductless air conditioner split unit to remove
if the unit contains R12 or R22 you are not permitted by law to do the work yoiurself .. you have to have a "certified" person to reclaim the freon ... you might be able to get away with removing R134A (check local law) if thats what it has ... there is a service port that you can hook gages/hoses/vacuum pump up to .. (if not, then one must be added, usually in the form of a saddle valve that penetrates a low side feed pipe ... you should vent it into an approved tank or bladder (like a big balloon) for disposal or reclamation .. there may be a community service in your area that comes out and reclaims freon from old refrigerators and such .. in my area there is a free service that will reclaim the refrigerant and take away the old equipment .. i think its free or low cost .. some people simply vent R134 to atmosphere but that is polluting and may violate some laws .. R134 was thought to pose little hazzard but that is being reconsidered now in many countries
you can become certified yourself by attending a class and taking an exam that shows you understand the dangers and are aware of the law ..
SOURCE: Freezer begun tripping our 20 amp breaker for some reason
ok hi there i viewed the specs for this freezer
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
this unit must be plugged into a 120v outlet with a 15amp circuit breaker dedicated (nothing else should on this circuit) so all by itself. you have to check the voltage outlet where you plug in. you must have at least 115v or better (125v the most) if you have less then 115v it will cause damage. ok you went and checked all this out and everything is 15amp with 115v or better and it still trips breaker.
ok the running amps is 6.8 amps so to blow the circuit you need 15 amp which is too high.
i suggest you call a refrigeration guy because he will be able to determine if the problem is the compressor (which has a 4 year warranty with truemfg.com only in the USA) or something else. Usually but not 100% what would make a freezer like yours to blow the fuse is the compressor. if it overheats it will do this, if there is a sudden high pressure within the system it will do it, if you have a condenser fan that is not running at proper speed it will do this...
the problem cannot be pin pointed understand please... you have to babysit it, watch for changes in the refrigeration system and the running compressor amps, voltage drops ( this will cause high amps) etc...
Refrigeration is not easy and alot of tech stay away... so those who stick it out make money cause you have 2 choices: buy another one and pay big bucks to get it fixed. at least see if you can find someone to come over (for like $40 - $60) and tell you exactly whats wrong with it... whew... hope this was helpful and not confusing...sorry
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
