Question about Samsung Refrigerators
Turn up the temp on a samsung side by side,lower drawer model, with digital display . touching the "Refig " button ( also marked as quick cool ) only sends temp down. how do we incr. to 37
    Sergeant:
  • 296 Answers
Are you trying to get the freezer temp down or the refrigerator temp? If it's the refrigerator, Samsung might have a cutoff of 37 degrees to keep you from getting the temp to low and icing over your coil
Posted on Mar 30, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
Anonymous
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
Anonymous
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
David Lowry
  • 59 Answers
SOURCE: Samsung Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Posted on May 22, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 26, 2009
Samsung rs263tdbp and demo/cool off mode will not turn off
from the manuals Page 1. Activating/Deactivating Cooling Off Mode When the refrigerator is in Cooling Off Mode (aka Demo Mode) the display will read "OF OF, O FF, or OFF OFF." Cooling Off Mode prevents the unit from cooling. It is used by retailers to display units without wasting energy.
Note: Models without digital displays will display scrolling lines when the unit is in Cooling Off Mode.
Tip: If your display panel has buttons that have to be pushed in to perform any functions, replace the word "Touch" with "Push" or "Press" in the following steps.
  1. Touch and hold the top two buttons on the left side of the display panel.
  2. Important: You must touch the 2 buttons at the exact same time. Not doing so will result in an unsuccessful attempt to activate/deactivate Cooling Off Mode.
    [img src="http://www.samsung.com/us/system/support/content/2011/04/25/h5408/Demo_Mode_250_Pix_1.jpg" align="bottom" border="0" height="127" width="250">
    Notes:
    • As long as the display panel is located on the exterior of the left door of your refrigerator you will use the top two buttons on the left side of the display panel to activate/deactivate Cooling Off Mode.
    • If your display panel is located inside of the unit along the door frame you will need to locate the words "Cooling Off (Hold 3 sec)" printed on the panel. The Power Freeze and Freezer buttons are the two buttons used for Cooling Off mode on these models.
    • Wi-Fi Touchscreen displays on RF4289* and RSG309* are exceptions to this article. Cooling Off Mode is activated/deactivated through the settings menu.
Apr 01, 2014 | Samsung RS263TDBP Side by Side...
Samsung model rs267 says OF on both temp displays
Freezer and refrigeration isn't working
There is no temperature indicating for Celsius of Fahrenheit it just displays OF.
The letters "OF" on the display of your refrigerator indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and the display returns to normal, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air. Thanks-Helpful?
Feb 07, 2011 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Have a Electrolux refrig. french doors and bottom mount. model ei23bc56iso Its shut off. The display in front at the dispencer says OFF at frezzer side and OFF at refrig side. No other displays or error ...
  1. Bottom Mount Refrigerator Ice Maker. When the bottom mount refrigerator is placed in Sabbath mode the ice maker will be automatically disabled. Please be aware however, that although you have entered the Sabbath mode, the icemaker will complete the cycle it had already initiated. The ice cube compartment will remain cold, and new ice cubes can then be made manually in the freezer section (using a standard ice cube tray) as needed for that Sabbath/Holiday.
  2. Sabbath Mode and the Perfect Temp Drawer (if equipped). The Perfect Temperature Drawer should be turned off for the Sabbath/Holidays. Before putting the refrigerator into the Sabbath mode, turn the Perfect Temp Drawer off by pressing the drawer on / off button. The display will show "OFF" and the drawer will turn off. Then enter the Sabbath mode function on the main refrigerator display. The drawer display will now not illuminate and the drawer will remain off until Sabbath mode is exited and the drawer is turned back on. The drawer can still be used as a non temperature controlled drawer in this mode.
  3. Press the display button few seconds and recheck.
---------- Check out thanks.
Aug 27, 2010 | Refrigerators
I have a ge refrig pfs22misbww model# fl044796. Temp lights for the frig and frezzer are out. when i hit the - to lower the temp the lights go on but the refig is still not getting colder, then the light...
I believe your temperature board and lights are being affected by your motherboard part number WR55X10942 You may need to unplug and examine both sides of the motherboard to see if possibly burn marks or loose solder connections are present. I will be here to assist you if you like, Thanks, Sea Breeze
Dec 27, 2009 | Refrigerators
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Overfilled ice tray lots of shattered ice, no "cubes"
Hold in the freezer temp and the power cool buttons for 12 seconds, when the display changes toggle the refrigereator button untill desplay sAYS 03. Then toggle the freezer temp button or poew freezew button to a lower setting than what you have now.
Dec 22, 2008 | Samsung RS2630SH Side by Side Refrigerator
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
May 17, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung side by side
you can reset the fridge by pushing "Power Freeze" and "Power cool" at the same time
it worked with my fridge Samsung RS21DAMS which stopped after a power cut and was also flashing at the digit of the fridge temp display
Mar 28, 2008 | Refrigerators
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
104 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
