Question about Refrigerators
The door ajar alarm is beeping but the door is closed. I reset it and a minute or so later it goes off again. cant get it to stop. This is a stand up freezer
    Sergeant:
  • 296 Answers
It sounds like your door sensor switch failed so no matter what you do, it will keep going off until you replace it. What's the make and model of your unit?
Posted on Mar 31, 2019
    New Friend:
    Problem Solver:
  • 6 Answers
Most likely, or first thing to check is the door switch. When the door is open push the switch to see if the light goes out, if it doesn't replace. If the switch works look through a tiny crack and see if the light goes out. If it doesnt maybe a spacer pad fell off.
Posted on Mar 30, 2019
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: Interior Lights and Door Ajar light stay w/beeping noise.
Try spraying WD-40 into the door latching mechanism (door side). I learned this fix after two battery replacements, but have only had to spray twice in the more than seven years of ownership
Posted on Jan 29, 2009
Anonymous
SOURCE: door ajar light on
The drivers side door switch goes bad all the time on those, try replacing or check if its sticking.the small little button int the door jam.
Posted on Feb 01, 2009
Anonymous
  • 3 Answers
SOURCE: 2003 Volkswagen Jetta Door Ajar Light wont turn off and car alarm
The problem you are experiencing is the drivers side interior light switch is not working. This is usually found in the door latch on later model cars and usually requires the complete latch mechanism changing. However it would pay to check that your car doesn't have a pin switch fitted in the pillar.Unfortunately I think you have the former.
Posted on Jun 12, 2009
Anonymous
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
diodeic
SANYADE OMOTOLA
  • 1622 Answers
SOURCE: The alarm beep which tells you to close
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Posted on Aug 15, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Door ajar alarm keep beeping every 5 minutes and door is shut
was the replaced control panel a used unit
are the door hinges and seals ok
still maybe a faulty door sensor
Jun 17, 2016 | Refrigerators
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Door ajar light - power windows and alarm
you may have a broke wire in the door harness
Jul 16, 2009 | 2002 Ford Explorer
Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Feb 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Open Questions:
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
