There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
SOURCE: freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
SOURCE: Fridge/freezer beeping
SOURCE: fisher and paykel E240B refrigerator
I called F&P customer care when my fridge did this, and apparently 11 beeps means the compressor has failed. I hope you got someone to fix your fridge! I decided to post a solution as I couldn't find one online anywhere!
SOURCE: We have an E388 upright freezer...motor is still
dear sir/madam
i think your freezer,s indside motor is faulty so its not rotating motor is not working so freezer ,s evorator cycle is not having complete its reson for not cooling .
please contect to your freezer maintenance personnel for further action
hope answer the question
thank you.
please vote!
SOURCE: I have a Fisher Paykel E388 upright freezer which
Cold air always settles on the bottom Check the door seals above the cold area . Check for broken seals ,cracked seals and seals that are not touching the frame. Place a thin piece of paper between the seal and the frame and close the door . If the paper falls or is easy to pull out that may be your problem. Test at various points around the door.
