NZ/Aus product line, Can getting settings mode (Spin + Temp) Hold - but only has brightness/sound/language settings. Tried (Power + Start/Pause combo (both soft keys)) but won't power up.
SOURCE: Hotpoint acquiarius WF645
To exit test mode, press start, display goes wild) press start again (display settles down) Then press on/off button and start buttons to gether and hold for a few seconds, machine will now read D;end, or similar, will now work okay
SOURCE: service manuals and diagnostic codes with results/reset code
Click on Fisher & Paykel (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line!!
SOURCE: Microwave key pad stopped working
Okay, thank you for that.
You have a failed membrane keypad, but on this model, it is not available separately.
You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
It costs more than just a membrane would, but is much simpler to replace.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you remove your circuit board from the old frame and install it in the new frame.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: soft/hard reset combination keys doesnt work for nokia 6280
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
