Question about eMachines Computers & Internet
I turn my emachines EL1200-07w and it has black screen that says starting in safe mode but then just goes black and does nothing else.
  • eMachines Master
  • 5,627 Answers
Hello and good morning.
emachines are old and now owned by acer.com (gateway,etc)
they OWN many old names.
you are running XP right? the last man on earth to do so?
XP is a virus magnet and doomed, it is time to upgrade.
this PC is 2007 made. so is 12 years old, today..
the RTC coin cell battery will be no good now, replace it for $2
then reset BIOS inside BIOS screen " set default"
then test the HDD, to be sure it is ok, if not? then reloading any OS of any kinds is not going to work with any bad HDD.
Last, reload a new OS.
there are the steps. and can be expensive, spent on any PC this old with zero street value. ($0 if broken a it is)
Posted on Apr 01, 2019
6ya staff
SOURCE:
Anonymous
  • 141 Answers
SOURCE: Emachines T2385 startup problem
Psu is a Power Supply issue but the black screen with a blinking white line is not.
The blinking white line can mean there is no instructions to tell the Computer to boot up. Which could be possibly the system battery (cmos) or Hard Drive.
I would narrow those 3 things down first.
Posted on Jul 01, 2008
Anonymous
  • 197 Answers
SOURCE: Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
Posted on May 28, 2009
sabharish
sabharish
  • 297 Answers
SOURCE: Dell Inspiron blank screen
You can restore your system in your safe mode.
To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in the On this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Complete page is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
Posted on Jun 11, 2009
vinhson65
  • 257 Answers
SOURCE: my cp will not boot up
You go to Bios mode and choose the frist boost is DVD/CD then save new setting and turn off your comp. Insert Win XP operation disk and see if it could fix the problem.
Posted on Aug 12, 2009
adnanbhatti
Adnan Bhatti
  • 1188 Answers
SOURCE: vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Posted on Sep 19, 2009
Testimonial: "Thanks! Maybe I should consider the fact that I am using my perfectly performing Iphone to fix my poorly performing PC during my next purchase :-) "
How to restore emachines E732ZG
If you have a disk in the dvd, remove it and try to start. If that fails press F8 while starting and see if you can start in safe mode. If that fails , you will need to insert an operating system disk , and when you get the disk info loaded on the screen, type fixmbr . Hopefully one of these will work
Nov 27, 2013 | Computers & Internet
My emachine laptop wont work i turn it on and it comes up with a blue screen then truns off now it only turn on to a black screen and a mouse pointer is there any way to just reset it to what it was when i...
try rebooting the computer and as soon as it turns on tap on the "F8" key until a new boot menu appears, choose "safe mode" if the computer starts successfully in safe mode. restart it and allow to boot normally. If this fails comment back as to whether it started in safe mode or not and I will attempt to help you further,
Mar 02, 2013 | eMachines Computers & Internet
I have a emachine computer that wont start up goes to a black screen that says start windows,normally ans never starts
Did you press the Enter key? when you see that black screen, you can use the cursor keys to move up to "Safe Mode with Networking". See if that option will work. If so, run a virus scan with the free Malwarebytes from malwarebytes.org
Did you make any changes to the system just before this happened? In Safe Mode, you can remove any software that was recently added.. that might help; then restart the system.
Aug 07, 2012 | Computers & Internet
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dec 30, 2011 | eMachines T Computers & Internet
When I turn my emachines netbook on, it gives me a error screen saying 'run in safe mode (recommended) and 'start windows normally'. No matter which I choose, it goes to the windows load screen...
there is a recovery tool on emachines usually loaded during you boot the system to safe mode. on my case i restore my machine to its default and reinstall my o/s.. hope it helps
Sep 05, 2011 | eMachines eM250-1915 Netbook
My emachines t5234 starts up and goes to the the boot menu, and when i try to run it in anything it shuts off. if i try one of the safe mode options it shows me the black screen with the long list that you...
the windows operating system needs to be reinstalled...
if it continues then its a hard drive issue
use an ubuntu live cd to back up documents you need from the hard drive
Apr 24, 2011 | E-Machines eMachines Desktop PC
I have an Emachines EL1200-07w desktop
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
  7. Set your computer back to the state when it was working fine.
May 06, 2010 | E-Machines eMachines Desktop PC
Acer 4650 Travelmate Black screen
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer TravelMate 3260-4874 Notebook
My cp will not boot up at all. the light turns on but nothing comes up.is there away to fix this? i did try starting in safe mode which is f8 (i hope) it ask to start in safe mode,safe mode with...
Aug 12, 2009 | E-Machines eMachines Desktop PC
Safe Mode is also Black..
I found your other posts regarding this problem. I believe it may be that your monitor is failing. Do you have another monitor to try? Another clincher is to start the computer, do the login, and when the monitor goes dark, turn off it's power button, and turn it back on after waiting for 30 seconds or so. If the monitor lights and looks normal then goes back off, it's the monitor at fault.
Dec 12, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
