If it ain't turn on at all check your fuse box. It could he a fuse under hood in car under dash. If the fuse is good then pull the radio out. Do a smell test on it. If you don't smell anything suspicous then check your red yellow and ground wire. Yellow being your switched 12v which turns off and on with ignition. Check red wire also. Also ground wire is very important.if none of those work it will need to be replaced. Check fuses carefully. A blown fuse can sometimes be easily missed
SOURCE: iPOD to Sony Xplod CDX-S2000 CD-R/RW EQ3
you car stereo doesnt have any aux inputs you can check up more on this site
http://www.crutchfield.com/p_158S2000/Sony-CDX-S2000.html?tp=5684&tab=features_and_specs
the rca inputs are for a pre amp or an amplifier
SOURCE: Wiring diagram
There are many CDX models, but try this site:
http://www.usersmanualguide.com/sony/car_audio
SOURCE: need wiring digram for sony xplod cdx-gt200
Go to link below for manual on page 22 has wiring diagram.
http://akamaipix.crutchfield.com/Manuals/158/158GT200.PDF
SOURCE: I need the wiring diagram for Sony Xplod CDX -
I think this is what you are looking for:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT310&LOC=3
SOURCE: I need a wiring diagram
Hi, this is the wiring diagram for the model in question :--
Hope this helps
