SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
SOURCE: Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
SOURCE: Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
SOURCE: My GE Dryer model DWSR483EA1ww will not stop & doesn't dry quick
first thing you should do is check the flow of your vent, a clogged vent can cause all your problems check it outside while the unit is running you should get really good flow compare it to the flow of the dryer with the vent hose off the dryer completly. they should be fairly close or just run it with out the vent hooked up to the vent if you have an electric but not with a gas dryer
SOURCE: Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
