Televison & Video Logo
A
Anonymous Posted on Apr 02, 2019
Zenith 50" plasma tv no sound
Check input or source if ok check audio see if speakers on
5 Related Answers
wfdiver
  • 5 Answers
  • Posted on Jun 03, 2008
SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
williamskemi
  • Posted on Dec 03, 2008
SOURCE: zenith plasma tv
my 52 inch zenith plasma has no picture,but has a perfect sound.what could be the problem?
Anonymous
  • 92 Answers
  • Posted on Sep 08, 2009
SOURCE: heard a loud pop in my zenith 50
LG Inside.
Needs either a Y-Sustain or a Z-Sustain.
Whichever has the blown fuse inside.
Anonymous
  • 608 Answers
  • Posted on Dec 15, 2010
SOURCE: MY 50 INCH PLASMA TV WENT BLACK I CAN ONLY HEAR
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Anonymous
  • Posted on Mar 17, 2011
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
I lost picture and Audio,I just replaced the Y sustain board and still doesn't work, what else should I do?
If you get a blue screen when it's on, try feeding in an external audio and video source, like a camcorder or VCR, and see if it displays. Check setup or input selection. If it's set to video or HDMI source and nothing is plugged in, you'd get a blue screen.
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
No sound from my TC P50U50 plasma tv
Check the speakers first. If found OK, check and replace damaged component/s at it audio output circuit board, or replace the audio output circuit board as card basis.
Hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
2answers
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
After warm-up screen flashes and loses color but comes back on and off intermittidly. This is a 50" Zenith Plasma tv. thanks.
Sounds as if a cable connection is bad. Check the cables first. If cable are good, change inputs, if cables are bad replace cables. If it's component, make sure that red, blue or green didn't come loose on both sides...the tv and the source. If you still have problems, check for red video noise on the screen itself, preferably when it's on but with on input (black) If you notice this, your plasma is failing.
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
I have a samsung 50 inch plama no audio....
Have you checked the connections to your speakers and if they are connected correctly from the TV and to the speakers. Also as it is only two months old the product should still be covered by its warranty so contact your supplier if you have no luck.
HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
1helpful
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
