I have a lathem time clock pc600 that won't get past the initial loading screen. Please wait and the hour glass is the only thing I am able to see. I've reset it by using the reset button on the back. It doesn't work. Is there any other method I could perform to get the thing to work.
SOURCE: player won't work
Go to the RCA Opal website and download the newest firmware. That may clear it up.
SOURCE: System Initializing Problem
same problem with mine...i tried to use rockbock firmware...it works but you have to be patient...you have to reset it time and time again before it works....it still works anyways rather than the iriver firmware...
SOURCE: RCA OPAL M4208RD-B Goes to please wait screen and stays.
RCA M4208
Make sure the lock switch on the back is in the unlocked position. For the player to say "Loading," especially the first time you plug it into the computer, is normal - your computer is communicating with the player, installing drivers, and trying to load the Easy Rip Software. If it stays on loading past 10 minutes, however, something is not right. If you have selected to open the device automatically using Windows Media Player, you are headed for trouble, especially if you have more music and other files on your computer than the mp3 player can handle. If you have accidentally done this, disable auto-sync in Windows Media Player.
If you have checked the above, and you are still having problems, disconnect the mp3 player from the computer. Hold in the power button for 10 seconds or more to reset the mp3 player. Try plugging the mp3 player into the computer again. If it stays on loading for more than 10 minutes, unplug the mp3 player, go into the settings menu and change the mode from MSC to MTP or vice versa. If it still misbehaves when you replug the mp3 player into the computer, download the latest Easy Rip software from RCA's website and update your player's firmware - take note of the section they have on Windows Vista if you have Windows Vista. Good luck!
-Tha Mp3 Doctor
SOURCE: Can't set up the correct local time
The trick is to set the time and never have anyone call you :-)
Or, contact whoever your CID provider is and tell them the clock offset is wrong. In my case, I have a Packet8 box and I had to go in and make the time correct for my time zone. Access instructions were on their web site.
Carl
SOURCE: My VL-875 MP3 player will
My VL-875 MP3 player will not load past the "Please wait" welcome screen. It also will not turn off without having to press the "reset" button on the side
