Question about Frigidaire Washing Machines
Frigidaire washer and dryer beeping all night. This washer and dryer is stacked in a small opening in my condo so it is hard to get to anything but the front area. I have heard it is the control panel
Washer model number: FTF2140FS0 Dryer model number: FEQ1442ES0
6ya staff
SOURCE:
Anonymous
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
Anonymous
SOURCE: Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Posted on Jun 30, 2008
Anonymous
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
Anonymous
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Anonymous
  • 4 Answers
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Posted on May 30, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
How to open front panel
There were two (2) small screws at the very bottom of the front.
  • Remove them securing the dryer front access panel to the dryer cabinet.
  • Lift the panel until the tabs can be disengaged from the cabinet.
  • Remove the panel and set aside.
Installation Manual (see page 8)
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131661700p1-8.pdf
Owner's Guide
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131781700ceen.pdf
Operating Instructions
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/131919500e.pdf
Cutout Dimensions
http://www.frigidaire.com/products/images/documents/cutout_dimensions/lc.pdf
Energy Guide
http://www.frigidaire.com/products/images/documents/energy_guides/134089300-USA.pdf
Feb 18, 2014 | Frigidaire GLET1031 Top Load Stacked...
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Need new washer to stack on my dryer!
measure your dryer carefully and check with the dealer where you wish to purchase a machine, regarding
the stacking kit. It may work. They are general standard sized. Don't ry to gerry rig anything or you may have big problems. In your case I recommend using a well known SMALL appliance store that does theri own installations, so they will bring what they may need, but if yours works, they can still use it.Good Luck
Jul 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Directions on stacking dryer on washer
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
