SOURCE: washing machine slowly fills with water when off
Its likely the diaphragm on the water valve is clogged with hard water deposits and is leaking.
You can try to fix it by running some CLR cleaner through the water hose with it disconnected from the tap. or just replace the water valve.
a symptom of this issue is that water is always filling the machine. and you have hard water.
you can get to the water valves and take them out and replace/clean them by removing the top cover (3screws in top rear)
unplug the AC cord.
follow the water hose from the tap the first dual block you see has 4 wires and the hoses plastic connected to it. easy to remove.
But if the machine is not leaking all the time and the machine just wildly decides to activate the relays for water ( you will hear the solenoids click for more water flow then the issue could be the computer control unit.
SOURCE: Water keeps filling!!
sphion effect while the water comes in the water goes out ..because you never said that it overflows,,,so just put your drain hose up the height of the machine before it can go down,,,drain hose to low...onthejob
SOURCE: my low coolant light keeps comming on!
change the radiator cap. its a 7 dollar part that generally cures the problem. (the silver cap on the top left side of the radiator).
SOURCE: Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
