SOURCE: Disarming / Access Code/ Resetting
Ask seller or previous owner the code, or read in the manual how to reset the system to factory defaults
On the previous version (Simon3) it was press cancel + clock set + Minutes+ at the same time and the power up from battery
SOURCE: GE Simon XT panel lights window, door and motion indicators
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
SOURCE: GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
AlarmProfessor.net
SOURCE: I just bought a simon XT and the installer set up
Google the Simon XTi. YOu will find the manual online. I don't have this system, but am looking to install it. I did find the info for the manual online in printable form. Sorry, I don't remember the site.
