Question about Simpson Washing Machines
My Simpson 650 will agitate clockwise then starts to go anti clockwise but stops then goes clockwise again seems like it is lacking some power.
  • 1,360 Answers
Seems like the clutch has failed. Common problem when they get older. The machine will wash in one direction, but not reverse. You usually get all the clothes tangled up and causes it to keep stopping during spin. Have a look under the machine, if there is brown / black oil stains all over the bottom of the inside of the cabinet, that will be your problem. Most of the time, it wont be worth repairing.
Posted on Apr 10, 2019
6ya staff
SOURCE:
SOURCE: Dryer won't start, Simpson Eziloader 4kg
On dryers with the old mechanical timers you can turn the knob in either direction without harming the mechanism. On either type, even electronically controlled models with a problem like you described, there are a lot of possibilities. After confirming you have power to the appliance check the thermal safety fuse located on the heater housing.
Posted on Jan 25, 2008
Anonymous
  • 24 Answers
SOURCE: Hoover Washer only agitates in one direction
Check the paw. It is a plastic somewhat u shaped piece that sits on the bottom of the machine and is connected by a plastic lever and a solenoid. It usually breaks on the end and as such won't lock the gearbox in. If you keep running it like that there is every chance you will probably burn the motor out.
Posted on Oct 08, 2008
tellme2
terry weightman
  • 137 Answers
SOURCE: poor running suzuki gsf 650
hi m8,, 1st u need to check the timing with a time light gun,, and trottle the bike to 7000rpm, and see if the timing marks change as u r pointing the gun at it, if they do move ,,adjustment is needed, ,if all is ok u can do a test by taking a plug spanner with u,,and riding the bike up the road, trottle it to 7000rpm,and soon as it stutters hit the kill switch and coast to a stop,, wipp a spark plug and check the colour of the plug, ,u have to look at each plug tho,, if one plug is different colour to the others ,,then the cylinder that plug came from is the problem point,,, another solution is to get your carbs balanced ,,id advise u do this 1st really b4 doin timing check,, cheers
Posted on Jan 30, 2009
Jordan Schmidt
  • 58 Answers
SOURCE: My GE Wizard Washer will agitate or spin for a very short time.
replace the transmission. this job is better done after a few dozen bottle of your favorite whiskey. Check the timer controls to ensure timer is advancing properly. tranny's are notorious on ge's for this sort of problem as well as inner basket drive blocks coming loose. ge makes alot of great appliances, this just happens to be one of them that isn't. i trust their jet engines too, although hard to work on them from 30,000ft.
Posted on Jul 02, 2009
Anonymous
SOURCE: Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Posted on Jan 14, 2010
Simpson swt8043 top loader washing machine agitates anticlockwise only from new.
The agitator is designed to “ratchet” and turn one way but not the other. If your clothes are being twisted, that is most likely a transmission problem where it tries to agitate and spin at same time
Oct 05, 2018 | Simpson Washing Machines
Why has my samsung washing machine stopped turning both ways
can be the capacitor,if that doesnt work try checking the clutch pall
Aug 20, 2017 | Samsung Washing Machines
My Simpson eziset 650 won't complete a cycle it
The machine has detected that it's taking too long to fill, check the hose filters in the inlet solenoids (remove the hoses and you will see them) make sure your taps are turned up, If all seems ok then you have work inlet solenoid(s) and will need to replace 1 or both of them depending on if it does it on both hot and cold cycles.
Mar 05, 2012 | Samsung Washing Machines
Dec 27, 2009 | Washing Machines
Oct 08, 2008 | Washing Machines
New to this Machine. Unit washes and stops every 25 seconds?
Have you contacted Malber USA? 516-294-6660. They were helpful with my problem.
Aug 17, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
