Maybe this will help ...... I have a Korg M1 ..... it has a small button battery for maintaining memory and sounds .... mine lasted about 10 years ...... I looked up in Google how to change the battery .... I looked up in my M1 instructions how to reload the sounds .... I had lost all my synth sounds except the basic piano ...... I changed the battery and reloaded the sounds from a backup card I had bought years ago .... M1 works perfectly now .... you probably lost any saved songs .... contact Yamaha how to change the battery and reload the original songs .... any saved songs are gone .... next time, back them up ... good luck
SOURCE: displays code Scn
Either the keyboard is disconnected or the Keyscan on the keyboard itself is but. More than likely a loose connector.
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
SOURCE: Digital Piano has sticking key
Typically LOTS of screws... concentrate on those around the edge. USE GREAT care and force nothing when removing the cover...and great care of cables between the cover and the base. Mark the cables so you remember the direction they attach.
When you get edge screws out, then gentle lift and see where it seems to be held...
Some of these synths have 50 to take out to get apart. MOST are in plastic bosses and keep track of the size and length as you can put too long a one in the wrong place and crack the boss.
I use a compartmented plastic tray to keep the screws in order.
SOURCE: Problem with Yamaha YDP223 Digital
First thing is to check the connector is fully seated... sometimes most of the contacts make but one might not. Beyond that, contacts in the pedal are next suspect.
SOURCE: My Yamaha mm6 doesn't work
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
