Water Heaters Logo
B
Bruce jepsen Posted on Apr 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aurelia 2 semiautomatic pressure valve on top is open. Water pours out. What do I do
Joshua Jennings
Level 2:
Scholar:
New Friend:
  • Expert 85 Answers
  • Posted on May 02, 2019
 Joshua Jennings
Expert
Level 2:
Scholar:
New Friend:
Answers
85
Questions
0
Helped
52825
Points
239
Please post manufacturer, model, and serial information. This will help in diagnosing your problem.
3 Related Answers
Anonymous
  • 248 Answers
  • Posted on Oct 31, 2009
SOURCE: newly installed solar edwards hot water system and
system over/pressurised check overheat statbest of luck
Anonymous
  • 474 Answers
  • Posted on Nov 02, 2009
SOURCE: trying to drain water heater .. hooked up hose and
lime and calsium deposits build up over time in the bottom of the tank. you may have to remove lower element and with a wet dry vac cln out the tank
Anonymous
  • 961 Answers
  • Posted on Aug 06, 2011
SOURCE: the pressure release valve is
If the pressure relief valve has a flip lever on it that is extended up or out from the valve, it is in the open position and you will want to close it. If the tank had a big dent in the top, there is a good chance the fiberglass tank inside the outter metal housing could be cracked or broken. If it is leaking around the valve, you might have bad threads that the valve threads into. It's hard to say without seeing it but, the inner fiberglass tank is not built to be beat on. You can try to pull off the inspection panels and see if you can see exactly where the leak is coming from but, make sure power is off to unit before you do anything.
I have an Atwood water heater G6A-7E, heater heats up but no hot water flow after 15 seconds...Flushed system with water and air, put water to it and the hot water flow stops after a few seconds....
First check that any by-pass valves are in proper position. Remember, cold water has to enter in bottom fitting at back of tank, and hot water comes out at top fitting. Thus any valves that may be there, need to be in open position, and any valve between those 2 lines will need to be closed. If all valves are in proper position and working as they should, I would suspect you have a faulty check valve between top (hot) line fitting and tank. One easy way to check that before replacing it, would be to shut incoming water source off, whether running off pump or hose attached outside. Then relieve all pressure in system by opening taps until all pressure is gone. Now, go outside and open pressure relief valve carefully ( in case it's hot ) and make sure pressure is relieved there as well. Now, carefully hold pressure relief valve open while you have someone turn water back on, and see if you get good flow from pressure relief valve. If you get good pressure coming out of there, that tells you your tank is getting full, and you have water coming in as needed, so problem has to be on hot side ( top fitting ) and/or onward from there, which would be check valve fitting at top next to check. Remove the check valve and If you don't have a new check valve to try it, just put a short galvanized 1/2" pipe nipple in there for now if needed and that should do it, just attach your fitting directly to nipple. Before you do this, make sure you have removed all aerators etc on taps that may be plugged and tested pressure that way as well just in case. I have seen all of them plug up at same time before. If you remove them and get good pressure, then problem solved.
Only about a cup of hot water will come out, then it gets cold.
You need to check 2 things. First, go outside and carefully open pressure relief valve at top of tank,(careful in case hot water spurts out) and make sure there is water in it. Second, look at back of tank inside RV and check your by-pass valves(s) for proper positioning. Cold water enters the water heater at the bottom fitting, so that valve has to be open, as well as leaves water heater at hot fitting at top of tank (the highest fitting) so that valve as well needs to be open. Any valves that may be in between those 2 water lines need to be closed. I am assuming that the heater starts runs, shuts down etc, just not running any hot water through hot side of taps, correct?
2helpful
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
2answers
MY Atwood 6 gallon water heater will start heating the water. I turn on the water and it is hot for about 2 minutes and then is cold. The water heater does not turn back on. I waited a couple days and...
Try opening the pressure relief valve (carefully so you don't burn yourself) slightly, and see if water comes out and if it is hot. It sounds like you may have very little if any water in there. Check by-pass valves at back of water heater for proper positioning. Cold should go in the bottom, hot out the top. Make sure there is flow through any valves going into bottom, and any valve at the top.Any valves connected in between the hot and cold should be in the off position. If need be, to test if incoming cold water getting into tank at bottom fitting, shut off water, relieve pressure in system by opening taps until all pressure is gone. then close all taps. Now remove your drain plug, then turn water back on, and water should shoot out the drain plug hole with good pressure within a few seconds and flow steady while water on. If not you have a restriction such as valve in wrong position or faulty, so try moving valve to get better flow out drain plug. If flow out drain is good, then make sure valve at top fitting on back of tank (if any) is also open for good flow . Any other valves should be closed in between those 2 lines. Let me know what you find.
6helpful
2answers
My water heater is pouring water out of the overflow hole, I turned it off but how can i fix it?
Your pressure relief valve is open either due to an increase of pressure (that is what it is designed to do) or more likely .the spring in the device is weak and requires replacement . pick one up at Lowes and reinstall the same as removal .You will need a pipe wrench or equivelent and some pipe sealing compound.Hope this helps.
Hot water tank shuts down after5 minutes pilot still on water
Carefully catch some water in a container from pressure relief valve (pull lever slightly) at top of tank, and see if it's up to temperature. If it's hot there, I suspect your by-pass at back of the tank, is faulty. Depending on what by-pass system your using, it may be in wrong position, blocked, or mixing hot and cold. Cold water flows into bottom of tank, and hot out the top. If any valve in between the 2 lines, close it, and make sure valves in and out of bottom and top are open. Let me know what you find, or if water from pressure relief valve is not hot either.
4helpful
I have water pouring out of a pipe outside that is coming from my hot water heater.there is a cap missing but i'm afraid if i put the cap on the pipes will burst.what could be the problem?the water heater...
That pipe is connected to something called the T&P (temperature and pressure) relief valve. The pipe that connects to the valve should be run to a drain line so that the water goes somewhere other than all over the floor, but often it just ends a couple of feet from the valve. It's possible the valve has opened because the pressure in the tank is over its limit, but more likely it's the valve's fault. If the new heater was supplied without a T&P, the installer may have used the one from your old heater. Over time the spring inside the valve weakens. Then it can't hold the pressure from the new heater properly. A new valve is under $10 at home improvement stores or larger hardware stores. It just screws into the water heater, so it's simple to replace it if you have a pipe wrench. Turn off the water into the heater and remove the old valve. Use Teflon tape or pipe dope on the threads of the new valve (the store will sell that too), tighten it into the heater, then turn the water back on. That should end your leak. If it doesn't and the T&P valve still opens, you'll need to have a plumber check the water pressure in your home.
The pilot was out this morning and after I got it started, I got
Hi jeake9,
Yes, you are correct it sounds like the pressure relief valve. It is an important safety device that lets water out of the water heater when temp/pressure exceed the limit set on the valve. It did its job good.
Now the important part is to change out the valve and try to diagnose why it tripped. Odds are the water temperature was too hot AND the relief valve couldn't close because of mineral deposit build up.
Replace the relief valve and turn the water heater down for starters.
Please rate this response and Good Luck, Phil
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
