Question about Daewoo Washing Machines
How I fix error code E1 in my washer machine daewoo inverter Dwc-vd1213
6ya staff
SOURCE:
Anonymous
  • 143 Answers
SOURCE: Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Posted on Jul 24, 2008
Anonymous
SOURCE: error codes
just fixed mine
i cleaned the filters inside the water lines. disconnect lines where they go into washer use needle nose pliers to pull out screens clean with water and put them back.
this wasn,t the problem with my washer .
mine i took the cover off and found the clear hose from the drum to the water senser had disconnected reattached it with difficulty as i have big hands works fine now
Posted on May 06, 2009
Anonymous
  • 40 Answers
SOURCE: E1 ERROR CODE
Found the answer on the Uniden Site. Here is the Link to the Answer. http://www.mycusthelp.com/uniden/supportkbitem.asp?sSessionID=&Inc=1691&sFilA=Product&sFilB=Model&sFilC=&FA=4&FB=-1&FC=-1&KEY=error%20codes
Posted on May 14, 2009
r_dawg
Richard St.Clair
  • 50 Answers
SOURCE: daewoo a/c parts
www.Daewoo.BizRate.com mite beable to help
Posted on Jun 27, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
My DAEWOO washing machine shows E9 error . How can I fix it.
Following is a summary of your problem:
Daewoo Washing Machine Error Fault Code = E9
Fault Detected: Pressure Sensor Error
Washer Has Detected: Error with the pressure switch or level sensor
Check / Repair / Fix = Wiring to level sensor - Level sensor
You can check Daewoo Washing Machines' all Error Codes on the following link:
https://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/ Daewoo Washing Machine Error Fault Codes
Check the following link also:
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes
Feb 05, 2018 | Daewoo Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Model DWC-LD1421 WHAT DOES FAULT CODE LE MEAN ON THIS MODEL
    this is the code issue for the Daewoo washers things to check The washing machine or washer dryer door has been detected as open or unlocked.
    • Close the door!
    • Check the door lock switch
    • Check the door latch
    • Check PCB
    Mar 09, 2015 | Washing Machines
    Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
    • Close the door!
    • Check PCB
    Mar 09, 2015 | Daewoo Washing Machines
    My Daewoo DWC-UD1212 washing machine does not spin; and shows IE whenever the light indicator is on Spin. What should I do?
    not sure bout the IE error But I would check the clutch, the motor coupler, the door switch, and the belt if applicable?
    Feb 28, 2015 | Daewoo Washing Machines
    DAewoo DWC-LD1013 will not spin
    The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
    Jan 09, 2015 | Daewoo Heating & Cooling
    Daewoo DWC-UD1212 Washing Machine
    Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
    Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
    Washe machine problem
    The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
    Feb 26, 2007 | Daewoo DW500M Top Load Washer
    Washing Machines Logo
    63 people viewed this question
    Top Daewoo Washing Machines Experts
    Marvin
    Marvin
    Fahr Quad
    Paul Bade
    Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
