Washing Machines Logo
A
Abedin smakiqi Posted on Apr 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi,my washer machine miele w363 the rinse light blinking ! How to solve this problem _
Gerry Harvey
Level 3:
Genius:
  • Miele Master 1,482 Answers
  • Posted on Apr 15, 2019
Gerry Harvey
Miele Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378901
Points
4533
Try clearing the filter...pump .b
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Dec 30, 2007
SOURCE: Whirlpool GU2400XTPS rinse only light is blinking
mutiple keys stuck press keys one at a time then hit cancel
Anonymous
  • 16 Answers
  • Posted on Feb 08, 2008
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Anonymous
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Anonymous
  • Posted on Aug 07, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Anonymous
  • Posted on Sep 18, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
1helpful
The buzzer sounds and the rinses indicator light flashes and the programme sequence display " - - - " appears in the display. This occurs at the end of all programmes just as it starts to spin.
Hi - I will tell you whats wrong with the machine, but you will need to get someone familiar with Miele equipment to fix it for you.
On this particular series - Rinse LED flashing means 3 - 4 things could be wrong with the washer.
Tacho - generator is faulty
Drive fault - electrical problem
Motor - has issues with starting
Blockage - drains - drive unit
Restrictions - of the drum turning.
Electronics - may be a component with an intermittent failure/decay.
It would be either one of the above or a combination of 1 or the other...
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
2helpful
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
I owna W844 Miele washing machine. Shortly after I have pressed the start button, the "spoolen" light starts blinking and the washing procedure doesnt continue. Do you know which the problem may be?
Hi dear.If the machine starts the cycle but does not start agitate there are two things could be wrong.1- Good thing loose motor connection,2- Bad one is control board gone.To checked the loose connection,take out the detergent drawer.There are 3 secrews,unsecrew them.Bottom left hand side where the filter lid open it.free the drain hose.Out of the front doorjust under the filter lid,there is one little clip holds the door.free the door & cheked the motor connection.If it's loose,make sure firmly attach the connection housing.put the machine back in order & start the machine.If machine takes the water in & still not rotate the drum(If the rinse "spoolen" light flashing),you need to call miele service centre where you are to get it replace the control board.I hope that helps.Thanks.
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
3helpful
2answers
Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
6helpful
Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
10helpful
2answers
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
