Vizio D55U-D1 I performed a visual inspection and noticed a burnt spot on both sides of the video (main) board. Nothing else appeared burnt or loose. New board is in and the same problem remains. I'm not sure what to test (meter) or what I'm looking for to diagnose the problem any further.
SOURCE: Vizio 42 in L42HDTV10A no power no lights no nothing
You can look at the various module failure symptoms and service / replacement options for the L42HDTV10A here:
http://www.coppelltvrepair.com/search?Q=l42hdtv10a&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
SOURCE: No imaging, have sound, backlight, etc.
It may be an input cable problem. Check hdmi and or coax cables to make sure they are not damaged . If you have another tv hook cables up to it to make sure they are working. Hope this helps.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In my whole career as a tech, I never had a defect on a place I would have wanted it. And believe me, if an integrated circuit is defect, or even a diode, you won't see it on the outside of the component. Most of the time you need more than just a multimeter. Any way, to use it, you at least should have a diagram pointing out what voltages you should measure on what point. If not it is pointless.
Be aware even the 120 volt AC, can be deadly, so don't play around with that voltage.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
