Question about Toshiba Televison & Video
Hello. I'm looking a Toshiba power supply(39l4300vq) (v71a00029000)and I wanted to ask you if you can tell me the number of the component. IC chip 7-dip (U801) in board. What is its serial number.
    Top Expert:
  • Toshiba Master
  • 66,132 Answers
Sorry we have no clue here
Posted on Apr 17, 2019
6ya staff
SOURCE:
Anonymous
  • 65 Answers
SOURCE: Nero 7 Serial Number
see dere is lots of version of nero i m givin u d seriall no. but if it not suited ur nero version den u can find more seriall no. frm seriall.com
becaz it is impossibal for me to givin all seriall no.
urs seriall no.4C85-1000-0805-0001-4046-4697-X622
Posted on Jun 19, 2008
Anonymous
SOURCE: DPS-210EP-2 power supply blew up
hi there the 8 pin ic in question is a Viper22a available from good electronic stores i got mine from
Cricklewood electronics for a couple of quid , also replace the capacitor c72 47uf
hope this helped
my board is DPS-210EP B REV 00
should be same
Posted on Jun 14, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
Anonymous
  • 4 Answers
SOURCE: Need info on component 3071 on power supply board - burned up.
Its been a while since i worked on that power board. But I believe you are refering to the orange diode that runs into the single connector for the video board next to the power supply. I replaced mine with a 1n914 diode after replacing the 2200uf lytic cap and the tv fired right up.
Posted on Sep 11, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Hello!Sony SDM-HS73 power-inverter problem
At this point you may have bad transformers, bad tuning cap, you need to check the frequency of the inverter oscillator to see if both of them are running at the same frequency, the bad one may not be. The Inverter/power supply is not made by SONY, Powernet makes the board. Please see what went wrong with the one I fixed.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
One thing to keep in mind, when the board turn into carbon (blacken), it will conduct. The circuits operate at high voltage and high frequency.
Posted on Apr 09, 2010
I have been trying to turn on my Toshiba 55HT1U television, but it will not come on. I get a little green power light but the screen is still black.
Hello, Thomas!
Looks, like there is an issue with inverter or inverters power supply(24v).
first thing to do: poke your set open, get to inverter make sure it has +24v in a main fuse. If so, in most cases: check fuse for continuity. Must have a multimeter to do that. Some LCD panels have 2 inverters: Master and slave. Known for frequent failure. Easy to determine: usually, on board IC chip bursts on failure. Or, if you really lucky: you may see "bloated" capacitors on those boards, as well on your power supply. I'd start with power supply, then check inverter(s). Good luck!
Thanks,
Alex.
Dec 20, 2011 | Toshiba Televison & Video
I am being asked for my "Built-In HDD1 User Passward" for my TOSHIBA Satellite A135-S4527. Please tell me what it is, or how I can bypass it. I can reload my operating system, that is not a...
Toshiba Notebook PC's in the A105 series, and A135 series, suffered a lot of issues with asking for a HarDDrive password.
[ BIOS
Basic Input/Output System.
A small program contained in the BIOS chipset.
{Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A Processor is an I.C.
Ram Memory uses I.C.'s on the sides. They are DRAM chips.
Just two examples of I.C.'s used in a personal computer }
When you power on your computer the first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
{Simple explanation}
WinXP, and Win 7 are two examples of an O/S.
BIOS gave the harddrive in your laptop the moniker of HDD1.
If there was another harddrive installed also, it would be HDD2.
(HDD 1, HDD 2 ]
Reloading the O/S may, or May Not stop the request for the HDD1 password.
Most of the time? No.
Removing the CMOS battery (RTC Battery) will Not fix this issue.
{Real Time Clock}
It's a glitch in the BIOS program.
Toshiba is aware,
http://www.insidemylaptop.com/my-toshiba-laptop-displays-password-prompt-on-startup/
One solution (Besides Toshiba Support),
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
{ NOTE*
When you go to perform a BIOS update, make SURE the power will not go out.
If the power goes out during upgrading, you will wind up with an expensive doorstop, or an ornament for a table.
A battery backup device of some sort is recommended }
For additional questions, or comments, please post in a Comment.
(Believe upper right of your page. FixYa is constantly revamping in order to improve)
Regards,
joecoolvette
Sep 09, 2011 | Toshiba Satellite A135-S4527 Notebook
Location of convergence chips in Toshiba 57H81.
hello if you can use a soldering iron you shouldn't have any problems but you will need to test the resistor in front of the ic and the capacitors at either end of the ic ! the ic usually located to the right hand side of the tv behind the tuner board connected to metal frame called a heatsink 2 big black chip good luck
regards
shaun
Mar 27, 2010 | Toshiba 57H81 57" Rear Projection...
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Thanks,
Dan
Oct 23, 2009 | Audio Players & Recorders
Chip 48 is fried and i need to replace it preferably with another kind of chip for which i need technical advice on which one to use
The IC which got burnt was for SMPS regulator. And this is necessary for constant DC supply to all components on your other board. So go on the shop and ask for specified regulator IC and also read all datasheets or documentation before replacing it.
Rate this solution if it was helpful to you.
With Regards,
Shyny
May 29, 2009 | Computers & Internet
I Need a power suply
These units don't have a separate "power suppy" per se. There is a power transformer and a separate board that contains the standby power supply components. The main power supply components are on the main board.
Rather than looking for a "power supply", what is the problem with the unit? Is there a standby light?
Dan
Mar 13, 2009 | Sony Audio Players & Recorders
A faint thin, line across my toshiba 32 inch. It was built in 1989, but I don't have idea what model it is. I replaced a few caps around the verticle IC, and the IC itself. I still get the same thing,...
the conversion chip is powered by seperate power from the transfomer + -- volts
here is I believe what your conversion chip # is stk392-110t and here is the NTE specs.
http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
you can use the specs. to check voltage pins, ect.. ,if that is the numbers.
to see if the chip is faulty then check resistors, caps , and voltage to the chip , a pr or fuse may have blown for the - and + voltage to the chip. if it is bad it would be wise to replace the vertical deflection chip as well ( hopefully yours is still ok) , because of the vertical control in the conversion chip.
you can also check for the power on the wires from the CRT board that comes from the flyback transformer ( NOT the HIGH VOLTAGE wire ).
also after you have unplugged the tv and dicharged the flyback to the chassi ground you should check the components on the crt ( cathode ray tube ) board for any bad measurements of the components.
Oct 13, 2008 | Televison & Video
1800FP power supply
The best way to get this to Robotek is to go to the home page and select find experts. Locate his name and use the ASK ME option. I will forward the link for this string to him as well.
Dan
Jul 02, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
