Question about Simpson Washing Machines
My Simpson power washer with a Honda cg190 engine shimmied off a platform and bounced on its head down 2 steps. The washer will not start
Only visible damage is slight dent on the Honda cover plate at top of Power washer
  • Jim Donnelly
    Jim Donnelly Apr 18, 2019
    Engine not mother
    Top Expert:
  • Simpson Master
  • 33,548 Answers
Is the spark plug broken? is the dent on the valve cover??
Posted on Apr 18, 2019
6ya staff
SOURCE:
Anonymous
  • 242 Answers
SOURCE: 2010 Honda Odyssey rear bumper was slightly
yes grind back fibreglass the fill ,smooth down repair and prime and paint
Posted on Dec 24, 2009
ourhowse
Dar
  • 2007 Answers
SOURCE: 07 Expedition second row seat head rest cover plate removal
There should either be a little button at the base of the headrest that you push, or a small hole in the rod part, with a hole in it. Push in the hole with a pen, or a small nail to release the headrest.
Posted on Dec 27, 2009
Anonymous
SOURCE: Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
Posted on Apr 28, 2010
angela olsen
  • 132 Answers
SOURCE: My convertible top won't go down and the trunk
check your fuse panel to see if its a fuse problem.
Posted on Nov 08, 2010
Testimonial: "Thanks for your prompt reply."
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: We have a brand new Simpson- Honda 3,000 psi,
Hi and welcome toFixYa, I am Kelly.
When you say it stalls is this fuel starvation or does it act like you shut off the ignition switch?
This should have the Honda GXC160 5.5 Hp engine on it. With the fuel selector off, have someone one remove the float bowl and check for debris in the very bottom of the float bowl. Also use come carb cleaner and spray into the main fuel jet located in the threaded are where the bowl nut screws into. The main fuel jet has a pin hole in it that must be free of obstructions.
Since this is a new unit you may just have some dried fuel in the fuel passages. With the float bowl off use a spray paint can lid and turn on the fuel selector. It should fill the lid in 8 - 10 seconds to the point you will shut off the fuel before it overflows. If you do not have this kind of fuel flow start looking at the main fuel line from the tank to the fuel selector. Check for a fuel filter and a debris bowl. I think the debris bowl is located directly under the fuel selector. It unscrews CCW for cleaning. Just clean it out and re-install same.
The last thing to check is to remove the main fuel line from the carb and check fuel flow. You should have good fuel flow with the fuel ine disconnected. If you do have good fuel flow here and you stilhave the stalling problem the float will have to be removed and the float needle will also have to be removed with the float. Once the float and float needle are removed spray carb cleaner into the float needle hole to force any debris back out the main fuel line connection.
Re-assemble everything... turn on the fuel... check for leaks and then start the unit. This should solve the stalling problem. If it presists... the pilot jet will need adjusted. This is absolutely the last resort repair because if you do anything to this screw you must replace the pilot valve screw and cover. It also mandates the use of loctite 638 on the tear drop shaped screw cap. (the old cap breaks off for pilot scre removal.) See check sheet below.
Here is the carb check sheet:
http://www.honda-engines-eu.com/en/images/59139.pdf
This file will download before you can open it.
Thanks for choosing FixYa,
Kelly
Posted on Jun 24, 2011
Where can i find a pressure washer pump for gentron 4200
Grainger.com will have a replacement you can order
I’m happy to assist further over the phone at https://www.6ya.com/expert/gregg_78ecbb34e27be215
Jun 11, 2014 | Simpson WS5040H Water Shotgun 5000 Psi...
Im not getting the simpson 3200 psi to shot out water
Give us a all when you. An be at the washer.
http://www.ppe-pressure-washer-parts.com/page/419383926-32577450
Nov 03, 2013 | Simpson PS3200 Powershot 3200 Psi Direct...
Pull cord compartments have come off
With your question, I'm not sure if your looking for another or what your specific needs are but I believe this is it.
http://www.ebay.com/itm/NEW-PULL-START-RED-RECOIL-COVER-11HP-13HP-FITS-HONDA-GX340-GX390-/111147183055?pt=LH_DefaultDomain_0&hash=item19e0e36bcf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 02, 2013 | Simpson WaterBlaster Commercial Gas...
My 13.0 honda gx390 motor has no spark and will not start
try disconnecting the black wire which runs across under the fuel tank you should have spark.
Nov 15, 2011 | Simpson Taskmaster Industrial Gas Powered...
I have the honda CG190 engine on the pressure washer and the manual has a section for draining the fuel tank and carburetor. (storing your engine) Draining the Gas tank is no problem. I do not seem to be...
Easy way to deplete fuel in bowl is to shut off fuel while you are using pressure washer and are about to finish your work. Just run the engine till it quits. Difficult way is to remove nut under the bowl. You might also look into new products designed to pour into tank for storing your engine and a method to displace the water from the pump and infuse oil. Good luck with your unit/
Jul 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
My Simpson Water Shotgun shuts down about a minute into the wash
Have you checked the oil level? Some engines have a sensor that shuts it down if the oil is too low
Jul 16, 2009 | Simpson PS2600 PowerShot Commercial-Duty...
Washing Machines Logo
46 people viewed this question
Top Simpson Washing Machines Experts
ANTISPAMMER
Kardoc
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
