SOURCE: Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
SOURCE: my bike has 21 gears the new wheel only has 18
yes it will. You will have to adjust the gear shift cable so that it doesn't go past the 6th gear on the wheel (as you would've had a 7th gear) otherwise your chain will constantly slip off the wheel and jam up
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
SOURCE: i need to get my
http://www.parktool.com/blog/repair-help/cassette-and-freewheel-removal
The tool(s) will depend on the brand of cassette/freewheel. Available online (Performancebike.com) or any Bike Shop.
examples:
http://www.performancebike.com/bikes//CatalogSearchResultView?storeId=10052&catalogId=10551&langId=-1&pageSize=16&beginIndex=0&sortBy=Dollar+Rank%2F%2F1&searchType=resultSet&cn1=&searchTerm=freewheel+tool
SOURCE: Have a British Eagle Tundra 18 speed men's bike,
It can be repaired by using a tap and di set. If you dont want to buy one of those i would take it to a bike shop and they should be able to do it for you for around 15$
