By far the most common cause of what you describe is
Demo Mode is turned ON
If am certain you have already checked to make certain there are not too many appliances plugged into the same outlet, and that you are not trying to run your Bosch through a power strip or so-called "surge protector", which are worthless troublemakers.
SOURCE: Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
SOURCE: My Jenn-Air gas cooktop burner keeps clicking
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work, u nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
SOURCE: cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
SOURCE: Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
SOURCE: I have a Jenn-Air CCE3401 Electric Cooktop I want
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
