SOURCE: Setting Time and Date on phones
Just got this phone. It is indeed day/month/year. European style. NOT what we want for a phone in the states. Really annoyed with the fact there is not an option. Might be returning it.
SOURCE: Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE
**8463 – Display shows PASSWORD:
Then type in 23646
(Note this number will not show on display)
The display will show
hours.
Press CHANGE
(or NEXT if you do not need to change the hour).
Enter the hour (00 to 23).
If number is less than 13, the display shows AM.
Press CHANGE
to select PM.
Press NEXT.
The display shows minutes.
Press CHANGE
(or NEXT if you do not need to change the minutes).
Enter the minutes (00 to
59).
Press NEXT.
The display shows year.
Press CHANGE
(or NEXT if you do not need to change the year).
Enter the last two digits
of current year.
Press NEXT.
The display shows month.
Press CHANGE
(or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT.
The display shows day.
Press CHANGE.
Enter the day of the month
(10 to 31)
Press
RLS (release) to exit.
SOURCE: helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
SOURCE: date and time
When you open the battery compartment, there is a small round battery(under the cr1220) slot, lift up this slot and take the battery out and replace it, this is the battery for that function of the camera.
