SOURCE: trouble focusing with sigma 70-300 DL macro super lens
It will not focus on anything closer than 5 feet.
(From Sigma lens literature) Capable of macro photography, this
lens has a 1:2 maximum close-up magnification at the 300 mm focal
length. It's the ideal high performance lens for portraits, sports
photography, nature photography, and other types of photography that
frequently use the telephoto range. It also has a switch for changeover
to macro photography at focal lengths between 200mm and 300mm with a
maximum close-up magnification from 1:2.9 to 1:2. The minimum focusing
distance is 1.5m / 59 in. at all zoom settings.
SOURCE: sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
SOURCE: auto focus not working
Your Sigma 28-300mm doesn't have a HSM-motor as far as i know. When you switch it from MF to AF, you also have to disengage the manual focusing ring by pulling it towards the camera, or pushing it away from the camera. Using the AF without unlocking the manual focusing ring may damage the AF motor.
I hope this helps,
/Chris
SOURCE: Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
SOURCE: auto focus not working properly.
Hi It sounds as if the scale ring has gone ie needs a new one are you uk
