SOURCE: Looking for kwh use for a dryer
KWH = The Wattage of the Unit multiplied by the length of time used.. IE: a 1000 Watt Unit that is used for One Hour is equal One Kilowatt Hour. (1000Watts = 1KWatt) Wattage is The input Voltage multiplied by the Current draw. IE: 115Volts the unit draws say 4Amps equals, 115x4=660 = 660Watts.
SOURCE: gas in oil
Maybe. Put a pan under the genset, drain the oil, leave the drain plug out until you figure out why the carburetor was allowing too much fuel to flow (likely a stuck float). When you think that you have it figured out, replace the drain plug, add fresh oil, remove spark plug, and perform a compression check to see if the rings are worth it. If compression is low, then you can decide if it is worth your time and expense to repair the engine.
If memory serves, Harbor Freight sells compatible, if not identical, engines that will fit this generator.
SOURCE: i need an owners manual for a chicago electric generator
ago electric Generator Manuals\r\n
The Harbor Freight web site has PDFs for most of these generators. Go to.
http://manuals.harborfreight.com/manuals/XX000-XX999/XXXXX.pdf
Replace the first two XXs with the first two digits of the model number, and the last XXXXX with the model number.
For example, the manual for model 65414 would be on the following page.
http://manuals.harborfreight.com/manuals/65000-65999/65414.pdf
SOURCE: CRAFTSMAN®/MD Electric Snowblower owner's
If this is a Craftsman product then you should be able to enter the model number here and get one.. The manual tab will be on the right after they find it for you. A lot of repair information is not available in manuals, but Sears manuals are known to have parts schematic breakdown lists and diagrams, plus you can purchase from the online parts breakdown lists.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26132896&sid=PSx20071217x00001d&OVMTC=b&OVKEY=sears%20part%20direct&creative=726752&adcid=1987828
SOURCE: i have a problem with
did you blow out old gas from gas line going to carb? if this generator set up over the winter with no use, it probably has water condensation in the gas tank which has gotten into the gas line and carb. If you didnt do it already, blow undo the gas line off the tank and use compressed air (or by mouth) to blow out all the fule out of the line and carb. If you did not drain the old gas out before adding new gas, there still may be water in the tank and line. Try this and see if it fixes it. Give it time for the new gas to get through the line to the carb. To avoid this, keep the fuel tank full especially over the winter and you will not get any water condensation.
