SOURCE: my saniflow saniplus has stopped pumping water
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
SOURCE: Frigidaire Affinity washer: Straining water pump? Humming.
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
SOURCE: Sanipro continuously runs,however, not pumping
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
