Televison & Video Logo
A
Anonymous Posted on Apr 27, 2019
How can I unlock osd on my TV viewsonic n2011
  • Anonymous Apr 04, 2020
    hold the menu button in for 10 seconds the free manual cover this.
goneforever.
Level 3:
Top Expert:
  • ViewSonic Master 14,531 Answers
  • Posted on Mar 02, 2022
goneforever.
ViewSonic Master
Level 3:
Top Expert:
Answers
14531
Questions
0
Helped
3263980
Points
66315
THAT MODEL OF TV IS A TELEVISION
A 20 INCH OLD TINY TV. (For school dorms/)?
there is no menu button on the TV just on off, and up/down channels TV
the remote (lost that) has (input select key)
Composite, component (YPbPr), S-video, RF (antenna/cable
my wild guess is you did not read back of TV or monitor to learn what model it really is and posted wrong topic.
and yes all monitors by them do have unlock menu button.
this TV does have power lock.
page 6 shows power button lock
https://www.manualslib.com/manual/306712/Viewsonic-N2011.html?page=8&term=lock&selected=2#manual
quote:
Note:
1. Press VOL+ and MENU buttons at the same time to lock power button, and
press VOL+ and MENU buttons again to unlock it.
2. Press VOL- and VOL+ buttons at the same time to lock OSD menu, and press
VOL- and VOL+ buttons again to unlock it.
and page 18 covers osd feature set.
this TV
Attique-ur-Rehman
Level 3:
Top Expert:
  • ViewSonic Master 2,677 Answers
  • Posted on Apr 04, 2020
Attique-ur-Rehman
ViewSonic Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878095
Points
8006
OSD Lock: Press and hold [AUTO] and the up arrow for 10 seconds. If any other buttons are pressed the message OSD Locked will display for 3 seconds. OSD Unlock: Press and hold [AUTO] and the up arrow again for 10 seconds.
http://www.viewsonicglobal.com/public/products_download/user_guide/Display/VA1903A/VA1903a_UG_ENG.pdf?pass
  • goneforever. Mar 02, 2022
    ATTIQUE IT IS TELEVISION NOT ANY KIND OF VA190O3 AT ALL,. READ THE POST AGAIN.
    MOVED IT TO TV TO, LESS CONFUSING.
  • Anonymous Mar 02, 2022
    page 18
    Note:
3 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Jun 08, 2008
SOURCE: WHAT IS OSD ON A VIEWSONIC N 2011
OSD is basically the on screen display, meaning the various menu options that appear on the screen. You can turn it off by hitting the menu button on the remote till it disappears. Here is a user guide for your TV:
http://www.viewsonic.com/pdf/userguides/n2011-1_ug_eng.pdf
If you found the answer satisfactory, kindly take a moment to assign a Fixya rating. Thanks in advance..
Anonymous
  • 210 Answers
  • Posted on Jun 14, 2008
SOURCE: osd locked
Just drop them an email, you will need to change the country location first as i'min the UK, unless you are already.
Just click on your location on the map and then select the country: http://www.viewsoniceurope.com/UK/Support/Technicalmail.htm
Please rate my solution when possible....!
Good Luck....!
Cheers
Anonymous
  • 3 Answers
  • Posted on May 12, 2011
SOURCE: How do you unlock the
just press menu on the monitor in 10 minutes..
1helpful
I have a ViewSonic tv model N2011 when I press menu button osd locked is what I have in my screen, channel up or down same thing only the volume button don't make it can I know how to get ride of this...
To toggle the OSD lock off, press the Vol + and Vol - buttons on the Viewsonic N2011 simultaneously. This is shown in the manual on page 8, see https://www.manualslib.com/manual/306712/Viewsonic-N2011.html?page=8#manual . I believe these buttons are on the back of the unit on the right hand side as you face the TV.
I hope this helps.
tip
Viewsonic monitor Lock and Unlock instructions
OSD and Power Lock Settings
OSD Lock: Press and hold [1] and the up arrow UP for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
OSD Unlock: Press and hold [1] and the up arrow UP again for 10 seconds.
Power Button Lock: Press and hold [1] and the down arrow DOWN for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display?s power will automatically
turn ON when power is restored.
Power Button Unlock: Press and hold [1] and the down arrow DOWN again for 10 seconds.
May not work on ALL Viewsonics
http://www.viewsonic.com/assets/027/7939.pdf
Service manuals: http://ftpkuban.com/FTP/Manual/ViewSonic/
on Apr 14, 2010 • Computers & Internet
Osd display is locked on q22wb monitor
Please contact ViewSonic Customer Care to get support for this. There is a special set of macro keys to press to lock and unlock the OSD. But you need to call Customer Care to get this resolved.
My monitor osd lock . how i can open. viewsonic e55
Most monitors that have the OSD menu locked can be unlocked by holding down the OSD button for 20-30 seconds. Try it.
Hope this helps! :D
8helpful
Osd lock how to unlock....
Press the 1 key and the down arrow key for 5 seconds and it should unlock the OSD.
5helpful
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at http://www.viewsonic.com/assets/027/7929.pdf
10helpful
4answers
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
Top ViewSonic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
