When i bridge the remote wire from power wire on kenwood kac-7251 fan comes on but amp light doesnt until i take wire back off power wire and light goes back off quickly. I am using a brand new scosche loc2sl add-on amp adapter since my friends car is a newer Lincoln ls v8 and the stereo is tied in to the security system. But the amp worked fine until the scosche adapter just stopped working and it was returned for a new one. Even tried a kicker sm1-1500 on it and nothing still. Does anyone have any advice? I’ve never run into this problem before. Thank you.
SOURCE: install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
SOURCE: kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
SOURCE: leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
SOURCE: I had my Kenwood KAC-9105D amp and 2 Kicker subs
Kenwood WTF the same problem with the KAC-9105 all across the nation
Bridging the remote wire was just a test
Everything worked fine before and just stopped
