SOURCE: Sharp 2300n gets paper jam. It fold paper like an
When you clear the paper from the machine at the fusing unit, you can see 8 pawls, it looks like a hook but in a flat design. They should be touching the heat roller ( each has a spring to make it flexible ). If one not touching the heat roll it will caused the paper stuck to it so you will have the accordion paper jam.
SOURCE: Hi, New to Mac and trying to find sharp driver
Thanks for posting the obvious weatlandsvc. If i were to just point people to the vendors driver page, and pass that off as the answer, I would be fired. Thanks for the obvious.
I'm working on solving the real problem!!!!!
SOURCE: how to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
SOURCE: MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
SOURCE: SHARP MX 2300N Have cleaned the glass but still
Try cleaning the smaller part of the glass on the machine located to the left hand side of this machine!
