Question about Cameras
I have a KA12DO75O15O23U, with a EURO-PRO, “Ni-CD BATTERY, WHICH NO LONGER WORKS. The light shows it is charging but won’t turn on. Where can I buy a new battery??How much do they cost??? Thank_you.
    Guru:
  • 531 Answers
KA12DO75O15O23U What the heck is that?
Is it a camera?
Can you give us a hint about the make and model?
I laughed out loud because someone said spice (sic) old wire connectors as needed after buying a charger and checking AC to DC specs.
Yeah, right.
What a non-answer answer.
Posted on Apr 28, 2019
Testimonial: "Not a camera...a floor sweeper."
  • Tony Parsons
    Tony Parsons Apr 29, 2019
    If it is a floor sweeper, why have you posted the query in a forum dealing with cameras ?
    New Friend:
  • 26 Answers
Check existing AC to DC charging specs buy a generic charger, spice in old wire connectors if needed.
6ya staff
SOURCE:
Anonymous
SOURCE: Panasonic CD PLayer SL-CT520 Rechargeable AAA Batteries
Hey this is RaulFixall. You can fix this problem by naking the batteries, I'm mean by taking apart the plastic that cover them. You'll see that the led charging will turn on.
Posted on Jan 03, 2009
romsky79
rommel dadulla
  • 822 Answers
SOURCE: Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
Posted on May 29, 2009
Walter H Boehm
  • 998 Answers
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
Anonymous
SOURCE: Euro-pro EP-8000
I have the same problem and was wondering if you found a solution?
Posted on Jul 25, 2008
Anonymous
  • 340 Answers
SOURCE: dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
Posted on Dec 17, 2008
Can you help me with the battery for rq-sx35 cassette player
the batterys is known as a gum stick battery and can be found on ebay for a few quid,
Now you may find the voltage is about 1.2v and about 500/700mah
1.2v = the voltage and you must stick to this, Mah is how many hours the battery will last and now you will probably fine them in excess of 1000mah this also not an issue
The issue you may have is ni-cd or Ni-mh - if you have a ni-cd these are much harder to get, mainly from china on ebay for about £3 item 361298337890 or nicd from china is 400856146442 at £2.20 but will take a month to arrive
i do not know these sellers . so please view feedback of these sellers before buying
If its Ni-Mh you should be fine to swap it out, however a higher Mah will take longer to charge in the supplied charger but will last longer in use.
I cannot be certain if its safe to charge a ni-mh in a ni-cd only charger - if you can it will take a long time, and i cannot say how safe it would be.
a work around would be to purchase a desktop ni-mh charger for about £8 thats take all size battery's from aaa - d size as gum stick battery will fit inside the spring clips, but you must take great care on + and - poles and is the correct type and voltage its just a flat shape instead of round, but if u do go down this way by a standard charger not a superfast 1 or 2 hours as it just heats the battery's up too much
hope this helps
Aug 25, 2014 | Audio Players & Recorders
Tip
I am a semi-pro, long-time photographer and I just learned from a long-time pro...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Feb 01, 2008 | Samsung Digimax D53 Digital Camera
Light won't turn on Shark steam mop
I posted this video explaining how to clean the heater core of the S3501...it is likely a similar design as the Euro Pro.
http://youtu.be/S4NglGXVv50
Dec 09, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Sovereign Cordless Trimmer STO5.Red light on charger shows then changes to green to show full charge buts trimmer won't work!!! Help.
It's possible your battery is burnt out and the lights will activate back and forth as the sensor tries tell you its charged or not. You can take the battery and get it checked out where they sell that make of trimmer. have them install a new battery to see if that works for you. If that does not work its probably cheaper to buy a new trimmer.
Mar 23, 2012 | Garden
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
My Shark Euro-Pro EP750 has stopped charging. I
Either the battery is not making contact with the charger internals, or the battery itself is at end-of-life.
Feb 02, 2010 | Euro-Pro Shark EP750 Bagless Handheld...
What is the wright technique in Charging NiMH AAA and AA Cells?
Should work. As long as the voltage is correct the components of the charger should work. Depending on the type of "end of charge", i.e., time, voltage drop, temperature, it may take longer to charge with lower power ratings.
Aug 27, 2008 | Panasonic CR2016 Lithium Coin Battery
Nov 20, 2007 | Audio Players & Recorders
Cameras Logo
41 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
