Hi this is like you have a un open circuit
and if youre able to perform this task using a light probe
take a close look in circuit braker is near batterry
next measure continuity in your handle switch turning on and off
finally check the connectors to motor and if all ok great
you did it right
still with problems take it to an electrical moto service shop
dont forgett to comment
SOURCE: rover three wheel mobility scooter full charge
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
SOURCE: relay swith keeps tripping
Try replacing the relay switch, these sometimes get hot and fail and can be a fairly common problem on a lot of imported motorized electronics,
Good luck
Geodesygold
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
