No. If you are desperate for cooling turn breaker off. Remove tstat faceplate and put yellow and green both in with the red. Turn breaker back on. This will run the ac with cooling though nothing will turn it off but the breaker. Also a good way to ensure that the tstat is bad.
Did you press the Reset button?
What happened when you did?
What MODE are in you? AUTO or HEAT or COOL or OFF
SOURCE: My thermostat will not change the temp when trying to change
tHE TIME PERIOD SETTINGS ARE ONLY TEMPORARILY OVER RIDDEN. oNCE THE TEMP YOU SET IS REACHED AND THE UNIT SHUTS OFF IT DEFAULTS TO THE PERMANENT SETTINGS ON THE CLOCK.
SOURCE: wii remote
Hey did you try holding the red button where you put the batteries and holding the red button where you put the SD card all unit have an button so it can read the sensor from unit to controller....
SOURCE: '98 Jeep Grand Cherokee - My Heat/AC worked
The control for the AC/Heater door isn't working. To have AC the door has to close so that the hot air is not being blown into the car. When this door is closed it allows the cool air to pass through. This is either controled by vacuum or a ele. switch
