SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
SOURCE: 2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
SOURCE: Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Remove the motor brushes and check to see if it is worn. Check for voltage on the brush holder tube. If you have no voltages trace the wires from the electric source and switch. If you have voltage it is your brushes or armature coils. You can purchase parts from the below link.
http://www.ereplacementparts.com/milwaukee-907520-ser-239a-impact-wrench-parts-c-131_5120_5406.html
