Question about Datamax Office Equipment & Supplies
Have used a Datamax I4208 with LabelView without a problem. New system with Crystal Report/pdf output and the top line (3/8") fails to print. Label size 4"x 6" is unchanged. What needs adjusting?
Anonymous
SOURCE:
Anonymous
  • 53 Answers
SOURCE: Printing Speed
what interface are you using? sounds like windows is sending the data to the printer as graphics which is much more intence then EPL hence the delay between each label.
Posted on Nov 21, 2007
Anonymous
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
Anonymous
  • 27 Answers
SOURCE: Datamax M-4206 printing too slow
The way you can do this is to use Datamax fonts in your LabelMatrix program instead of truetype fonts like arial or times new roman. After making this change, do a test print and see if print improves. Another possible solution is use USB instead of Parallel cable (if you're not using it already).
Posted on Dec 30, 2008
bartech9
Roberto Martinez
  • 155 Answers
SOURCE: Datamax M-4206 - error light whenever load or print labels
Perhaps the sensor is out of position, you must move to the left. Also check that the hole senser is not blocked. Also verified that the sensor type (gap or black mark) in the software is correct.
Posted on Mar 16, 2009
AuntieDebbie
  • 5 Answers
SOURCE: We use the Datamax Printer to print labels with
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Posted on Aug 21, 2010
I have to reset my datamax i4208 every time I print. I cannot do more than one print job at a time. Help.
I need more information. What system are you using to drive the printer with? If it is a Windows computer it is almost certain to be a faulty/outdated driver.
Nov 17, 2016 | Datamax Office Equipment & Supplies
I am using Bartender software and a I4208 printer. It won't print on the first 1/10th inch of a 1inch x 4inch label. It also won't present after printing. Any help would be great. This printer is set up as...
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4308 Thermal Label Printer
Won't print the leading edge of the label
Sep 25, 2013 | Datamax I-4208 Thermal Label Printer
I am using LabelView to create a label that will be imported into an iSeries system. I am using Zebra 140xiIII as the printer in LabelView. When I import this label file into the iSeries system, I am...
iseries uses EBCDIC and the file is probably ASCII when importing from/to the iSeries charset convertions ensues, there must be some char that isn't translating well and thus converting itself in some control code, use DSPF or EDTF to open the file and check with F15 the encoding for more info I need to know what is your system CCSID
Apr 28, 2011 | Zebra 140XiIII Plus Thermal Label Printer
We use the Datamax Printer to print labels with labelview. The printer itself however keeps saying :position fault" how do I fix that?
Jul 12, 2010 | Datamax DMX-I-4208 Label Printer
Datamax I4208
position fault is normally a problem with either the formatting or the printer is not calibrated correctly.
Hold the feed button down until at least 3 labels pass by the sensor.
Also check to see the sensor is directly over the die cut on the label if more than 1 up label
Sep 22, 2008 | Datamax M-4208 Thermal Label Printer
Sep 09, 2008 | Datamax M-Class M-4206 Thermal Label...
Printing problem, preview problem
download and install pdfcreator in your system... it acts like a printer and so you set you printing destination to pdf creator and it will give the output that the printer would have given in the form of a pdf.... so you'll have what would have been the printer output... after checking this you can set printing destination to printer and get your doc printed.... or you can print the pdf...
May 14, 2008 | ComponentOne VSVIEW Classic Edition...
Printing Speed
Mar 02, 2007 | Zebra Eltron TLP 2742 Thermal Label...
Top Datamax Office Equipment & Supplies Experts
rongg
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
