Tip & How-To about Miscellaneous
My Iphone 6 plus was going crazy I think it's called ghosting when it does things without me touching it and when I do it goes nuts here's what I found out and used to cure it, so far this has been successful for two weeks.
open your iphone using online instructions
you will need an opening kit Amazon do them inc a suction cup. a pentelope screwdriver a lever a cross screwdriver also black electrical tape,
open as instructed careful to prize it on the rim, rest the screen open against a folded towel no need to remove it completely,
unscrew the five cross screws holding the display assembly cable, it's a metal plate with 5 screws these are all different sizes I used an address label with the ends folded down onto a sheet of paper with the sticky side up and wrote 1 to 5 around it place the screws on the label to hold and replace in the sequence you choose.
cut a piece of tape to fit the back of the metal plate trim around edges poke a needle through the holes to allow the screws easy access.
replace the metal plate.
close the phone, replace the screws, this works due to the metal plate originally not having a firm hold causing overheating on the cables causing the erratic screen,
I found this tip online on MacRumors posted by Mdsune, and it worked so well I am passing it on.... hope it helps :)
