Question about Sennheiser Audio Players & Recorders
HOW DO I CONNECT MY SENNHEISER RS 120 HEADPHONES TO MY LG UHD TV MODEL 55UK63
    Top Expert:
  • Sennheiser Master
  • 10,535 Answers
Hello Mike, your LG TV, does not have a headphone output, it only has optical fiber audio output
the options that I suggest are,
1) Connect the optical fiber output of the LG, to an AV receiver, that has said input and place the headphones in this equipment,
2) Buy an optical fiber to audio converter by RCA L and R and this is connected to a headphone amplifier
I send you links to the products that are sold in my country
I hope you solve your concern
Greetings Franco Dosil
This is the headphone amplifier
This is the optical fiber to audio converter by RCA L and R
Hola Mike, tu TV LG, no cuenta con salida de auriculares, solamente tiene salida de audio por fibra ?ptica
las opciones que te sugiero son,
1) Conectar la salida de fibra ?ptica del LG, a un receptor AV, que cuente con dicha entrada y colocar los auriculares en este equipo,
2) Comprar un conversor de fibra ?ptica a audio por RCA L y R y este conectarlo a un amplificador para auriculares
Te env?o links de los productos que se venden en mi pa?s
Espero logres resolver tu inquietud
Saludos Franco Dosil
este es el amplificador de auriculares
Este es el conversor de fibra ?ptica a audio por RCA L y R
Este es el amplificador de auriculares
https://articulo.mercadolibre.com.ar/MLA-784156450-behringer-ma400-ultra-compact-monitor-auricular-amplificador-_JM
This is the fiber optic to analog audio converter
https://articulo.mercadolibre.com.ar/MLA-707192478-convertidor-audio-digital-toslink-optico-coaxial-a-rca-nuevo-_JM
Posted on May 01, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Posted on Jan 21, 2008
Anonymous
  • 3 Answers
SOURCE: unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Posted on Mar 08, 2008
JL Thompson
  • 155 Answers
SOURCE: My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
Posted on Apr 30, 2009
JL Thompson
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
Anonymous
SOURCE: sennheiser hdr 120 headphones no longer hold a
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
Posted on Mar 06, 2010
How do I connect RS 120 headphones to Vizio M320VT TV?
Probably yes, connecting the RS transmitter to the composite audio output jacks (L/R) on the back of the Vizio TV.
Dec 26, 2014 | Sennheiser Audio Players & Recorders
Do I connect them to dish or TV?
The television audio out is the way to connect them. If you connect them to the cable box you may have audio lag.
Nov 01, 2014 | Sennheiser RS 120 Consumer Headphones
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
We have purchased sennheiser RS 120 wireless headphones but find our LG tv model 32LS3450 - TA does not have audio out, is there a solution?
Your TV should have Audio out somewhere, even if its digital audio out, you could output to a receiver and then hook your headphones to the receiver.
Oct 13, 2013 | Sennheiser RS 120 Consumer Headphones
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
Nov 10, 2012 | Sennheiser RS 120 Consumer Headphones
I have a new Samsung TV (LED 6000 series). I can not get my Sennheiser RS 120 to connect. I have plugged them into the audio out jacks at the back of the TV. They always worked perfectly with my old...
There is a possibility that internal speakers have to be turned off to direct audio output to the rear connector. You can confirm this by going to the initial set up procedure to disable internal speakers.
Jan 10, 2018 | Sennheiser RS 120 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
47 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
