All cycles do the same. Drain and Spin cycle does not work, the drain pump works, the drum rotates, but never reaches spin speed. Just keeps rotating at low low rpm.
SOURCE: Washer knocks half way thru wash cycle and never gets going in spin cycle
What kind of washer and do u have a model #
SOURCE: Final spin cycle for kenmore 417.40042990
This is an interesting problem. How long does it have to sit before you can get it to spin? Can you let it go through the cycle and then immediatly put it into spin and it work? This machine will not spin until the pressure switch senses the water has drained. So you could have a slow drain, a clogged pressure hose, or faulty switch. A clogged hose or faulty switch would usually cause it to fill with more water than normal also. A slow drain is most likely, check the drain hose when it is draining and see if it is putting out a strong flow or just slowly draining. I think you will find it to be slow. This will cause it to take up all or most of the spin time trying to drain the water. If it is slow draining, check the pump for a sock or some obstruction. If the drain is good, remove the top and remove the rubber hose from the pressure hose and blow through it. You should be able to blow through it easily. A restricted pressure hose will cause the machine to think it has water in it after it has drained.
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
SOURCE: rattling noise during spin cycle
Most noises
from a washing machine occur during the spin cycle. If you hear loud
thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
it. Repeat these steps if necessary.
SOURCE: washer wont run spin cycle model 417
The reason for your washing machine not to spin would be of a faulty motor coupling.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Thank you for contacting Fixya.com
Making Cash more than $15k to $18k consistently just by doing basic online work. I have gotten $18376 a month ago just by working on the web. Its a simple and basic occupation to do from home and its profit are greatly improved than customary office work. Each individual can join this activity now just by pursue this link........go to this site home media tech tab for more detail support your heart :*
HERE? www.profitclip.com
