Possible free manual to help, and has telephone numbers to call for assistance from the manufacturer.
https://partselectcom.azureedge.net/assets/manuals/D7141ACDAA583DEAEAC9FA0BF5D8BA4362025A77.pdf
All direction are on display when you close check a light comes its secure
of course after you put detergent open the fawcet water inlet
if any warm light on check the status probably you hava a damage switch door
SOURCE: QuietSeries 100 Maytag dishwasher
I read all the blogs on this dishwasher and decided to buy a new one and use this one as landfill...
Nothing but junk.
SOURCE: dishwasher does not run
1.Test door switch with a ohm meter it should read zero when door is latch..
SOURCE: Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
