Question about Panasonic Lumix DMC-TZ1 Digital Camera
Error message im trying to copy my pictures from the built in memory to the memory card but its sayin "some pictures cannot be copied" what do i do
    Master:
  • 619 Answers
The builtin memory was full , confirn first the picture transfer to your PC by opening on it before you erase from camera.transfer all record or picture to your PC and erase all pictures by deleting or formatting.
Posted on Dec 28, 2007
6ya staff
SOURCE:
Vivcam x137 troubleshooting
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 09, 2012 | Cameras
I was trying to upload photos onto my computer and I kept getting and error message:" I/O error. Process aborted." I switched to another USB port and got the same message. i am able to view the...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Jul 21, 2011 | Fuji FinePix Z10fd Digital Camera
How can i get the date and time shown on the developed picture
If you copy the data from the built-in
memory to the card, we recommend using
a card which has more free space than
the built-in memory (about 14 MB).
• If a picture having the same name as the
name of picture to be copied exists in the
copy destination, the picture will not be
copied.
•When you copy the data from the built-in
memory to the card and if the free space
on the destination recording medium is
not sufficient, the picture data can only be
copied halfway.
• DPOF settings on the original picture data
will not be copied. Set DPOF settings
again after the copy is completed. (P73)
• Only files conforming to DCF standard
(P49, 75) can be copied. (Files which do
not conform to DCF standard cannot be
copied.)
• It may take time to copy the data.
• Pictures which are recorded or edited with
other equipment may not be copied.
1 Select [YES] to format the
medium.
(The illustration is the screen when the
built-in memory is formatted.)
•When a card is not inserted, you can
format the built-in memory. When a
card is inserted, you can format the
card.
hope you can get something out of this...it came from user manual!
Jun 12, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Can't access photos
Insert the card...go into the menu and scroll to "copy". Follow the directions for copying the internal memory to the memory card.
Nov 21, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
I have a Lumix DMC-FS3 camera and if I don't put a memory card in it, I can't take any pictures because it says "built-in memory is full". When I tried to delete any photos that maybe on the internal...
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Aug 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Error message "unknown error has occurred"
how to transfer picturesd from digital camera to pc just watch video
Jan 07, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Dec 02, 2008 | Cameras
"Not enough space to copy files (Files not copied)"
This error message means that there is not enough space in the location you are copying to (internal memory or card). Delete pictures from the location you are copying to, or turn off the camera and insert a new memory card.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"No memory card (Files not copied)"
This error message means that there is no memory card in the camera. Pictures were not copied. Turn off the camera, and then insert a memory card.
Panasonic Lumix DMC-TZ1 Digital Camera Logo
560 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
