SOURCE: ntel(R) Wireless WiFi Link 4965AGN i want to
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network .
Click Here for more info
Hi Jaythan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
the manual covers,. this at dlink.com
why not read it, I can't because no D-link model stated of 100s possible.
if the router is yours , you can.
if owned by your ISP , call them they have the password to your router.
or us the method in your manual called.
WPS, the magic button if present,
RTM read the manual first.
or ask here if model number lost.
http://forums.dlink.com/index.php?topic=...
