The "Consecutive" shutter release setting is the default for Sports Mode so if you are using that you'll have to just practice a lighter touch on the button. Otherwise, and this is from memory, press "Menu" find "Drive" or a little icon that looks like a small stack of pictures and switch the setting to "S" for Single.
SOURCE: Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
SOURCE: when we advance film, it takes a picture
The problem is usually caused by a dirty release magnet. I can tell you how to fix it if you are handy with small tools
SOURCE: my disney pix micro digital camera wont take
hi i have the same problem with my cam i bought it for my doughter
try this it works for me
connect the usb cable to your camera into your computer it will say PC on LCD ( without battery)
then install the CD with the package finish the installation
then remove the usb cable to your camera and put in a new battery on it
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
SOURCE: Canon PowerShot S3 IS shutter problem. Shutter
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
