Question about Canon Cameras
I have a Powershot SX410IS Canon camera. I can take good photos with it. But as of today, when I Zoom in for a closeup shot, the screen goes completely white. What is wrong and how can I fix it?
6ya staff
SOURCE:
Anonymous
SOURCE: Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
Posted on Oct 25, 2007
t00nz
CameraR
  • 4738 Answers
SOURCE: my camera displays a "white screen" when i take photos "outdoors" or during daytime outside
Are you sure that you are in full "auto" mode when you are taking your pictures? Make sure that the mode selector is set to the first red camera (without the M) right next to the little blue arrow.
If you already are in full auto, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Your camera is not capable of taking 15 second exposures. Instead try putting it in manual mode, turn off the flash, take it in a darkened room, take the picture, and open the battery door while the red and yellow lights are blinking. Give it several tries, but note that the chances may be very slim for success as the shutter symptoms suggest that it is stuck open.
Posted on Jun 02, 2009
Kevin Chong
  • 12 Answers
SOURCE: White photos canon A470? i have a canon
I had this problem too, I think it's the shutter problem, it doesn't close
when a picture is taken, therefore, causing the over exposed photo...I've sent it back to canon, still waiting for the reply...
Kevin - Malaysia
Posted on Dec 10, 2009
old marine
old marine
  • 2261 Answers
SOURCE: How do I take black and white photos using a canon powershot?
Place the camera in P, Tv, Av, M, Movie, or Stitch-assist mode. Press the Func/Set button, and scroll down to the "My Colors" icon on the left side (second or third icon down, should show "My Colors Off" at the bottom of the LCD). Now use the left/right buttons to select "B/W", and press the Func/Set button again.
Posted on Mar 16, 2010
Jonathan
  • 85 Answers
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Posted on Jul 08, 2010
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
LCD screen Black - manual Zoom not working
Hey,
It sounds like you're having the same problem,
Here is a link
http://www.e18error.com/repair.html
It may be usefull,
good luck mate!
Jul 26, 2010 | Canon PowerShot A630 Digital Camera
I don't know how to get it to take extreme closeups
Hi there please follow the link below for user guide & use the zoom ring or macro mode( control dial) for distance & close photo taking. Thanks.
LINK --- click here.,
Apr 07, 2010 | Canon PowerShot S3 IS Digital Camera
I have a Powershot A85 and am trying to shot silver jewelry and am having a problem getting a clear picture. I have lost my manual - can you tell me how do I get a clean clear picture to put on a website?...
Recommend a room with good ambient, non-direct, lighting. Also place the camera in "Portrait" mode (the dial selection with the lady's profile). Also turn off the flash by pressing the lightning bolt button repeatedly until you get the icon with the slash through the lightning. Next put it in close-up macro mode by pressing the little flower button. Next use the timer to take the shot, by pressing Func Set, then scrolling down to the mode selection, and then scrolling right to select the 2 second option.
The camera is now set for such a closeup. Recommend using a tripod to keep the camera extra steady during the shot. If no tripod is available, recommend bracing the camera against another object, such as a chair to help keep it steady. Aim and zoom at the piece of jewelry, push the shutter halfway down to focus on the jewelry (should see a green box). Once you get the green box indicating focus, press the shutter all the way down to start the timer. Hold the camera extra steady until about a second after the shot.
Good Luck!
Feb 04, 2010 | Canon PowerShot A85 Digital Camera
PORTRAIT SETTING ON Canon Powershot A710 IS GIVES EXACTLY SAME PHOTO AS ON AUTOMATIC. NEED I ACTIVATE SOMETHING ELSE TO GET A BLURRED BACKGROUND?
Portrait provides extra sharp focus on the subject. It also opens the aperture some, and may in SOME cases give you a blurred backbround depending on the distance of the subject and background to the camera.
If outdoors, consider setting the camera to manual flash so that it will lighten the subject. If indoors, consider turning off the flash. You may need to provide better external lighting on the subject, or use a tripod and ask the subject to hold still during the picture.
Try increasing the zoom (best is to set it to maximum), and then adjust your distance from the subject to get as close as possible. Note that you still might be standing relatively far away because of the zoom.
Another way to experiment further with focus and blurred backgrounds is to use aperture priority (Av) mode on your dial. Use the right/left button to set the lowest "f-number" on your screen. The lower the number, the greater the aperture. All other functions of your camera will automatically compensate. Again, use max zoom in taking closeups with low "f-numbers". Also experiment with the manual focus to pay particular attention to achieving sharp focus on your subjects eyes.
You have a very capable camera. It can do what you're thinking of. You just need to practice with it. It's digital, experiment with the above techniques. Throw away the bad pics and keep the good, noting which technique worked best for the lighting and situation.
Dec 28, 2009 | Canon PowerShot A710 IS Digital Camera
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Use of macro digital feature
hi,let me just inform u that the macro mode is only for outdoors.So on the side of the camera u will find a sliding switch.Just slide it to the opposite direction to turn off the macro mode.Since u wanted to take pictures of jewelry pieces,turn on the flash if u have one and then take a closeup shot with good lighting conditions.If its too bright then use only the flash,if u r not satisfied with the quality then use only lights and then take a pic.Still face any prob plz get back to me.
Sep 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
The focus on my cannon powershot A540
Do you focus and then push the shutter button half way down to lock in that focus? Then all the way to take the picture?
Do you support the camera on a tripod or kneel down and support your arms on one knee or lean against some object to keep the camera steady> You can even press your arms tightly against your body before you focus and shoot. And be sure to press the shutter button very gently when you shoot so the camera will not shake or move.
Do you have the camera on the right mode for the photo you are attempting to take? Such as night/macro/action/ etc. Try taking photos on just the automatic mode to see if you can get focused shots. Make absolutely sure your camera is not in Macro mode ( a picture of a little flower on the screen) unless you are doing extreme closeup shooting.
Go to your menu>then setting> then set your camera back to default settings if you can. Or if you are unsure how the camera is set. If you do not have your manual you can go to the Canon website at www.canon.com and click on support or downloads and find the manual for your camera and download it. That may give you the answer you need as well.
Please get back to me if you do not have any luck and send along more info such as camera age.
Aug 08, 2008 | Canon PowerShot A540 Digital Camera
Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Jul 13, 2006 | Canon PowerShot S2 IS Digital Camera
Cameras Logo
43 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
