Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
SOURCE: No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
SOURCE: Where can I get New master faders for Mackie 1604
Your best bet is to visit the link below and select the "local distributor" option under section 4. You will then get contact information for a local distributor. I have found Mackie to be very helpful with parts requests. Please note that these units are a bit tricky to open up. Take care during dis-assembly not to tear any cables.
Dan
Link: http://www.mackie.com/support/
SOURCE: What is the value of mackie's faiders and master
The channel faders will be a 10K with standard fader taper.
The master fader is a 50K dual, with standard fader taper.
