SOURCE: how do i remove cover on food chopper? kenmore 665
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
SOURCE: how to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
SOURCE: How to clean the stainless steel stove top
Someone else suggested Easy Off Oven Cleaner (I used fume free). I just finished using the Easy Off (make sure you cover the electronic ignition) with Q-Tips and my top looks almost as clean as when I first got it.
SOURCE: I cannot clean my Samsung
when you clean the stainless make sure you wipe with the grain and not across it.
5-Qt. stainless steel bowl with comfortable handle offers enough capacity to mix dough for 9 dozen cookies, 4 loaves of bread or 7 pounds of mashed potatoes in a single batch. The bowl is also dishwasher-safe for quick and easy cleanup.
