Question about Canon Cameras
My Canon Power Shot A470 won't save a photo after editing. It says I need permission. I've gone through the administrator giving "full control" and it still won't save.
6ya staff
SOURCE:
Anonymous
  • 1463 Answers
SOURCE: driver download
check out here for the drivers LASER SHOT LBP-1120
riz.
Posted on Apr 22, 2008
informatica
Greg Cann
  • 1114 Answers
SOURCE: download manual function guide of canon power shot A470
Hi - You can download the manual from the link underlined in blue below:
power shot A470
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 23, 2008
Anonymous
  • 6 Answers
SOURCE: need to download drivers for my canon powershot
Go to this website http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=16338 select your operating system and then download and install driver, that should work. Guy
Posted on Dec 30, 2009
Andy
  • 262 Answers
SOURCE: I dont know how to
You have to unprotect it first. It's a bit confusing because the menu item probably only says "Protect..." but it also takes care of unprotecting too. Go into the menu for "Protect..." and navigate to the protected one. Whatever button you press to switch the protected status (it's the SET button on my Canon) you can use it to turn the protection off as well. When you exit the protection mode, you can delete it.
Posted on Jan 20, 2011
jimandfrank
SOURCE: Self Timer & Pause on a Canon Power shot A470
how do ifnd the self timer?
Posted on Jan 23, 2011
USING MS DIGITAL IMAGE STANDARD..TRYING TO DELETE PHOTOS..WON'T LET ME..SAYS IN REMOVEABLE PHOTOS/VIDEOS ON EMACH...WTH?????????????????????????HELP..PLZ
Hold on are these photos stored on a removable usb drive or an external drive ? and what is it with all of these Question marks ????
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Nov 29, 2012 | E-Machines eMachines Desktop PC
Canon Powershot A470 - outdoor pictures are white bright. Pls assist.
The Problem with the Canon PowerShot A470 Digital Camera Is That, where do I start? I took my mum's camera(without her permission!). And used it at school to take pictures during a Prefect Party I had. Everything went well till the lens jammed(fully extended) I tried switching it on and off, but I still got that error message.
Click Here To Watch Full Answer
Jul 18, 2011 | Canon PowerShot A470 Digital Camera
I have my canon a470 digital camera, recently i had a problem with my cam, while taking any picture it showing fully white screen pictures not at all viewing properly as well their is a white lines are...
This sounds like there is a problem with your camera's shutter mechanism and won't be resolved by changing your settings. You'll have to get your unit serviced by an authorized Canon service center. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 01, 2011 | Canon PowerShot A470 Digital Camera
Canon power shot A470 giving fade & Whitish display.
my canon Power shot A470 gives fade white photos but the movie is good it's normal what can i do for pictures.
Apr 21, 2011 | Canon PowerShot A470 Digital Camera
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
Dec 27, 2010 | Canon PowerShot A470 Digital Camera
My canon power shot A470 is writing card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 31, 2010 | Canon PowerShot A470 Digital Camera
NO PERMISSION TO EDIT OR VIEW As an administrator, I thought I have all the privileges to edit, view read, modify, execute and write any folder, but on certain folders I must first grant myself the...
you need to Take ownership of those files...
For Files:
takeown /f file_name /d y
icacls file_name /grant administrators:F
For Folders or Directories (will perform action recursively):
takeown /f directory_name /r /d y
icacls directory_name /grant administrators:F /t
Replace file_name or directory_name with actual file name or folder name, with path when applicable. The first command will take ownership of the file or folder specified, and the second command will grant full control permissions to administrators user group. Note that when using command for folders, to command will run recursively. To prevent the task been perform recursively, remove the “/r” and “/t” switch.
Above two commands have been scripted in Windows command shell batch script that easily perform the task of taking ownership and grant full control permissions to Administrators user group by typing simple command. Alternatively, users can add “Take Control Of” option to right click menu so that the next time you need to take control of a file with full control permissions, it’s just a one click task.
Feb 04, 2010 | Acer Aspireā„¢ T180 PC Desktop
Download manual function guide of canon power shot A470
power shot A470
Informatica
Aug 23, 2008 | Canon PowerShot A470 Digital Camera
Cameras Logo
37 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
