AKING AGAIN AS I RECEIVED GENERIC ANSWER THAT JUST GAVE A LINK TO PARTS AND THEN MARKED AS SOLVED! Click and shuts off OR no water fills.. Kenmore Washer Series 700 Top Loading 110.29132 - two issues, not sure they are related. It has power, starts with the few preliminary spins to check the load and balance ..however, one of two things happen. 1 either starts this clicking noise and powers off OR 2 acts\sounds like it is filling but never does does not power down. Tired unplugging to reset, no changes. No error codes.
SOURCE: Admiral top load Admiral washer
Could be the motor or belt, tilt the machine backwards and look underneath to inspect the belt, try turning by hand see if everything is free (will only freely turn in one direction only as brake acts in one direction). Check motor for rotation, remove the front panel for a look, to remove the front panel, at the seam between the front panel and lid push in a flat knife or screwdriver approx 4" in at each side to release the clips (one at each side). this will allow you to lift the top and then remove the two front panel fixing bolts 7-8mm to remove the front panel.
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
