Question about Sewing Machines
The upper thread pulls into the tension adjuster, and it becomes impossible to sew. D25001 machine
    Habit-Forming:
    New Friend:
  • 30 Answers
Adjust the bobbin case. theres a small screw that adjusts the stitch +/-. However you can purchase a new bobbin case and i t should already be adjusted when you buy it. Any sewing supply store should have them. be sure to take the old bobbin with you, so you get one thats the same. Have fun sewing!
Lynn
Posted on May 03, 2019
    Top Expert:
  • Sewing Machines Master
  • 8,546 Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
Anonymous
SOURCE: Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 30, 2008
Anonymous
SOURCE: Upper Thread Breaks!!!
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Posted on Jan 14, 2009
    paj42
    • 1116 Answers
    SOURCE: I can't get the tension on my sewing machine
    It is possible that you threaded the machine with the presser foot down.
    This creates loopy stitching because the thead never entered the tension control. Foot down = closed tension.
    Put the settings back to their normal settings.
    Raise the presser foot and re thread the machine.
    Posted on Feb 21, 2010
    paj42
    • 1116 Answers
    SOURCE: How to adjust the bobbin tension?
    On a sewing machine, the first "knob" in the threading process is usually the tension.
    Try threading the machine with the presser foot up, first. Sew a few stitches and then make adjustments as needed - right is a tighter and left is looser when turning the tension adjustment.
    I would recommend buying sewing machine. These little gadgets are cute, but they just don't do that well and are not worth the stress they create.
    Posted on Mar 18, 2010
    Try sewing but bottom thread on fabric is crumpING UP
    needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
    Oct 02, 2016 | Sewing Machines
    I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
    Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
    Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
    If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
    You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
    Manual: BERNINA artista 180 Support BERNINA
    Bobbin Tension How and Why Tension is Adjusted
    Understanding Bobbin Tension
    Understanding Thread Tension Threads
    How can properly adjust my tension
    Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
    Oct 02, 2016 | Bernina Sewing Machines
    Lower thread tension too loose
    sorry without knowing your MAKE machine I can suggest nothing helpful
    Aug 28, 2016 | Sewing Machines
    Is it possible to change the foot pressure.is it also possible
    Some machines do have a presser foot pressure adjustment. Since you didn't provide a make/model, we're not able to assist further. You'll have to consult your owner's manual.
    The upper tension is usually totally adjustable. As a matter of fact, the upper tension is the first place to adjust tension. Just be sure to RAISE the presser foot when threading the upper thread so it will seat in the tension disk. If the upper thread is showing under the fabric, it is too loose. If the bobbin thread is pulling to the top of the fabric, the upper tension is too tight. Tension will change with needle, thread, and fabric, so before beginning a new project, always test on a scrap piece of the fabric first. The tension is correct when the upper thread and bobbin thread meet in the middle of the fabric.
    As a sewist, you should become comfortable with adjusting the upper tension as needed.
    Apr 01, 2016 | Sewing Machines
    My thread bunches under me material and can' t sew
    Sounds like "thread nesting" also called "bird nesting." Usually, it is a result of incorrect threading, incorrect tension, or the thread not being properly seated in the tension disk.
    Remove the thread.
    Install a brand new needle.
    RAISE the presser foot and rethread the machine from the beginning making sure the thread path is correct.
    Set the upper tension to the midway point between low & high numbers.
    Test.
    The correct tension is achieved when the upper and bobbin threads meet in the middle of the fabric. If upper thread is looping under the fabric, the upper tension is too loose. If the bobbin thread is appearing on the top of the fabric, the upper tension is too tight. If it is difficult to determine what is happening with tension, try using a different color thread (but ALWAYS the same type & weight) in the bobbin as what is used as upper thread.
    Tension is static--it needs to be adjusted whenever a new project is begun because the needle/thread/fabric combination will affect the tension. A sewist should become comfortable with adjusting the upper tension on a piece of the scrap fabric before actually beginning to sew the project.
    The needle/thread/fabric need to be compatible to get the best result. All About Needles
    Sewing Machine Thread Bunching Up Here Why
    http://www.chholderby.com/tips-tricks-and-help/part-4-bird-nesting
    Mar 12, 2016 | Sewing Machines
    How do you adjust the bobbin tension?
    Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
    NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
    Jan 20, 2016 | Brother Sewing Machine - XL2600i
    My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
    Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
    Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
    Nov 29, 2015 | Sewing Machines
    How to adjust the tension
    The standard factory tension setting is the midpoint--midway between the highest and lowest. Tension will need to be adjusted to suit the needle, thread, and fabric for the current project. A sewist should be comfortable making these adjustments to achieve the best tension. The correct tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric--neither the bobbin thread is pulled to the top of the fabric nor is the upper thread being pulled to the underside of the fabric.
    Oct 21, 2015 | Elna 2005 Mechanical Sewing Machine
    Singer sewing machine 6215c trouble w/stitching - top looks fine, underside all loops of thread
    The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
    Doug
    Aug 05, 2010 | Sewing Machines
    Sewing machine tension
    Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
    Thanks!
    Robbie
    Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
    Sewing Machines Logo
    35 people viewed this question
    Top Sewing Machines Experts
    Chris Wetmore
    Marvin
    Marvin
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
