Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Aug 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman 1/2 HP Garage Door opener problem
I have a Craftsman 1/2 HP Garage Door opener. Both the remotes and wireless key pad stopped working at the same time. I replaced all the batteries with no luck. I also unplugged it overnight but still no luck. Wired wall control still operates the door correctly. Also, the door sensors used to activate the lights on the unit when I walked in and out of the door, but no longer do so. Can this be fixed or is it time for a new one. Frustrated b/c its only 4 years old!
Lisa Williams
Level 1:
  • Contributor 4 Answers
  • Posted on Aug 07, 2009
Lisa Williams
Contributor
Level 1:
Answers
Questions
0
Helped
2402
Points
7
The remote and the keypad work through a signal sent to the receiver while the wall console, as you said it's wired directly to the opener, so it's likely that the receiver is shot. I'd try reprogramming the remote to just rule out the chance that all code wasn't erased first. (Press the learn button on the back of the operator head, stand back 5 feet and within 30 seconds slowly press the remote button a few times to see if it operates the opener). If this doesn't work, you can install an external LiftMaster universal receiver with the correct frequency and you should be good.
If there's a purple antenna hanging off the head, this is a 315 freq, use a 356LM, if black it's a 390 freq, use a 635LM receiver.
Then you'll have to reprogram your remote and keypad to the receiver.
Since there's also the issue with the light, there's also a possibility the circuit board got fried. Did you have any storms lately?
Anonymous
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 188 Answers
Anonymous
Expert
Level 2:
Cheetah:
Answers
188
Questions
Helped
88777
Points
384
If your sysem has any type of standby battery replace it if you haven't. They are only really good for threeto four years at most.
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
I have a Craftsman 139.48847 1/2 Hp garage door opener. I can get either the remotes to or the keyless entry pad to work but not at the same time, Any suggestions?
If you have more than one remote and they all work but when you try to program the keypad it causes the remotes to quit working then your keypad is bad.
I have a 1/2 hp craftsman opener. Remotes work fine. Wired wall unit has a blinking light on the open button and will not work Lock pad and light pad work but not the operate pad.????
Try pressing and holding the lock button for 3 seconds to stop the light from blinking. Your wall control may be bad. Usually when that light is blinking it is the remotes that will not work.
When I push the button it only runs for 1 sec and stops...even with the door manually removed from the track system..I have a craftsman 139.53603 opener.
my craftsman garage door open about one ft and stop when i try to push the wall button or the remote pad it completely stop working
Craftsman 3/4 screw garage opener all remote stopped working
The radio receiver which is part of the logic board is bad. Check your warranty quick and call Sears.
LiftMaster 1/2hp: Key Pad Won't Work!
If you have a wireless keypad replace the battery.
1helpful
Garage door won't open.
The most common cause of this problem is the door sensors have been bumped and misaligned. They each have a small light that should be lit and not flickering. Tweak them until they are pointed at one another and the lights are lit.
2helpful
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
